I was having issues too. Went to tvapp instead. Better quality for me as well.
I am having the same problem Sports fire and Stream fire will not come on with SS vpn turned on .Had no problems untill today .
I decided to install Sportsfire on my Shield Pro as I had it for a backup a long time ago. Unfortunately it would not work well for me. Response in the app was exceptionally slow with about a 3 second delay between clicking and app responding. Every time I chose a specific Country and waited the 3 seconds for a response the app shut down and booted me out to the home screen. Uninstalled and reinstalled, switched vpn servers, switched DNS servers, nothing helped. App deleted.
Your Google play store is set to block some app that may be harmful so you have to turn that off and after turn it back on for safety
If you are referring to me I have the playstore disabled and google play protect off and are only activated when and if I want to update or check for updates.
Ok i was having problems downloading it cause the play store wont let me so i turn that off and was able to install it and it work ok for now cross fingers
Just an update .Tried to open Streamfire and Sportsfire today . Streamfire will still not open . Sportsfire will open but will not go any further .
i think there are problems at the moment with both i have used them both today but they are very slow to open and close
My Sportsfike is slow too. Streamfire will not load. I hole the development team can sort this out because I think bith apps were excellent before these recent difficukties
Same. Deleted both Sportsfire & Streamfire and then reloaded them. Neither will open with SS. Disconnected SS & they both opened. Tried numerous locations/countries with SS on and neither will open. Oh bother!!
sportsfire and sportstream back to normal now
Thanks for the heads up
Streamfire still does not allow Country selection, US only.
no its not as refined as sportsfire yet maybe in time
Going to check Sportsfire now.
All good in the neighborhood. Tx @pirate77 for the headsup and good morning matey.
morning @Miki glad all working your end
Streamfire now loads and works ok except there are no countries in the Country list so the only channels availabke are US ones
yes thats only on sportsfire atm the only way is if you know what channel for what country
The problem I’m having is that it continues to get removed from my apps list…
I’m using the T95z 128g streaming box…
I have to continually reinstall Sportsfire when I need to use it…
Any help would be appreciated…
Not sure of the OS of your device but with mine i needed to disable play protect in Playstore.
Its in the the Playstore settings.
