Installed Sportsfire.tv on the downloader but the apk won’t open. any thoughts?
sideloaded mine works fine
Used downloader and it “works”. Most of the streams are in SD and kinda fuzzy. If you are cheap and don’t want to pay for an IPTV service, this is a way to go.
i dont judge people and would certainly not call them cheap no need for comments like that
I side loaded, followed tutorial and works fine.
I wouldn’t call people cheap ether, alot of people here are on a fixed income so they have to prioritize their spending. Especially when it comes to whats better for them like iptv or real debrid.
The app works fine
Cheap? Absolutely not, what works for you might not for others.
It is simply down to choices and it MUST be respected.
Sportsfire is a very decent and user friendly app and that’s all that matters
Pls can you confirm your device?
If it is the Chromecast with Google Tv on Android 12, I’m afraid it won’t work.
Hopefully the Sportsfire developers will do something about the app not working on Android 12
Sprotsfire will not install on my onn 4K pro. I get to the install screen, hit install and nothing happens. Waited 10 minutes.
I cannot get Sportsfire to work while a Surfshark VPN is active. It works fine when the VPN is disconnected but gives a ‘Check your internet connection’ when it is on.
This is the situation on both my MeCool KM7 ( a few years old) and on a Firestick Max.
I have tried a few different Surfshark locations and countries but it won’t work in the same way. Incidentally Streamfire works fine when the VPN is on.
My version of Sportsfire is probably not the most recent. I tried to get the latest version but the new Downloader won’t download it, or anything else. It has permissions for downloading from unknown sources. I see that Downloader downloads to sdcard/Download/Downloader but neither of my devices has such a folder - no sdcard - and I can find no way of altering the download location.
I appreciate this is two issues in one post but they are interlinked. I have trawled Insider but found no solution. I am obviously missing something because other folk must be using Downloader successfully, as well as Sportsfire and Surfshark.
I’m stumped - can you help?
I have the same problem. Sportsfire will not work while Surfshark VPN is active and I get the same message ‘Check your internet connection’, which is fine by the way.
Thanks - it is useful to know someone else has the same issue. I also have tbe Windscribe VPN which has a small free allowance each month which I use to find out if Surfshark is the orobkem. Sportsfire works fine with that.
I have a problem with Sportsfire. I cannot get the program to install with downloader. Get to the page asking to install, and nothing happens. Tried on both onn boxes. With VPN (Surfshark) on and off.
I followed those instructions, but when I got to the install screen, clicked install and nothing happened. I even went to another tv with the original onn with the same result.
use this downloader code 119368
I was trying to update Sportsfire to the latest version and Downloader would not work. However when I uninstalled Sportsfire Downloader did download and install the new version.
Unfortunately it still does not work with Surfshark. This is annoying - I don’t like running without a VPN but to disconnect Surfshark you have to turn off the kill switch first.
I have not had this problem until recently but it has rendered an otherwise excellent app useless. I will now use RBTV77 instead.
What a pity. It also calls into question Troy’s recommendation of Surfshark as the best VPN.
try streamfire
