Sportsfire.tv won't open
Works for me now also using Surfshark.
Well that darn .1%
I dont see it listed in the Sportsfire schedule today. But that could only mean they are waiting to have the game link before showing it.
It is however listed on thetvapp.to
Enter that url in the device browser and at the top you will see ncaaf. Go down to listing 44 and you will see the link for the game and 730 start time. The link probably wont work until 730ish.
You may want to have them practice with a few earlier games to get used to the navigation.
Thanks for the info JPM69, that’s the way my luck usually goes… that 0.1% gets me everytime! Have 2 sources now, thetvapp you mentioned and streameast. That should be good enough, thetvapp is usually pretty darn reliable and so is streameast according to a few internet opinions. Thanks!
sports fire must be having problems was only listing scottish games in there schedule
The listings are by time of game. If you keep scrolling down you should see more.
Also, make sure you have either All Matches in the schedule (top right) or the specific sport you want.
FYI is Football is Soccer in the Sportsfire app. NFL and Ncaaf is American Football.
thx was talking about uk soccer they were only listing scottish games prob a blip
I dont believe its a blip. I tought they always show international Soccer matches. I have no idea if they are Scottish or otherwise.
Or is it strange that they are Scottish?
normally in the schedule it shows all uk games for today and tomorrow but no uk games are listed just scottish its not a probem can get elsewhere just thought i would let people know
Ah now i understand. That is strange. So no English Premier League as an example.
yes none were showing just scottish just looked again for sunday some are on there now so prob sorted it out hopefully
Dont forget about Streamfire app. It gives the channels not just the matches.
So if you know the channel you may find the match there. Even if the match hasnt started yet and the channel is broadcasting.
yes its fine it was only people were ringing me up saying no uk soccer listed i use streamfire a lot as well so i dont have a problem watching what i need just some of my friends are not tech savvy lol
There is only 1 EPL game today but that is not listed. The game is in progress and is available on RB77, so it looks like Sportsfire is having a problem getting a feed.
Tomorrow there are 2 EPL games but only 1 is listed at the moment
there was at least five epl games listed earlier then they disapeared one game is on now so its a problem there end not a big problem just a heads up for people in case they wonderd what was going on
If you mean the Liverpool game it is in the Sportsfire. Look at Channels under SkySports Main Event. And Uno (not english commentary)
Not sure why it isnt listed under the scheduled games.
I had the same issue. Won’t stay in the app list
I was able to install Sportsfire with my VPN. Tried out the app yesterday. I was able to find a NFL game and started to watch. Picture was a little blurry, but was able to make out almost all the details. After a few minutes the spinning circle showed up, but went away after a few seconds. Again, the buffering started and was happening more frequently. Finally, a screen showed up saying “trying to reconnect.” Never did reconnect. Download speed around 80Mbps/VPN.
Both Sportsfire and Streamfire are just not good IMO. I tried them out just to take a look but my experience was the working channels didn’t last long. Just nothing consistent and reliable Anyway not needed since my IPTV service is fantastic. Suggest you look into getting a paid IPTV for sports. BUT you also might want to check out the Live Sports in The Crew KODI Addon. Didn’t check yesterday but last weekend the college football games were streaming flawlessly on Saturday and same with the NFL on Sunday.
I am trying it now with Surfshark and it will not launch. If I turn SS off, it launches.
Getting curiouser. The Streamfire app downloaded with Surfshark connected, but would not launch. I’m using the Firestick 4K Max.
