STEP 5: Speed Boost Tweaks (Optional)
- In Skin Settings > General, disable:
- “Enable animations”
- “Enable blur effects”
- “Enable widget auto-scroll”
These save GPU/RAM — helpful on Shield TV if you want max speed.
have anyone ever try to play around with diggz build so much to learn it so perfect I never touch anything.
