I am using tivimate it also doing it on tv smarter to the sound is ahead of the picture I unplugged my box, cleared cache but it is still happening any advice it feels like a Chinese movie
The option you’re looking for is audio offset.
I found this using the search function. Best way to find info anywhere here on the insider.
Hi, if you’re using paid service this will be an voice synchronisation delay occured from service servers, and also due to the connection speed.
This happen oncen in the while, and this will go in few days, but you have to be pacient for it.
In my case I solved by cleared the data from tivimate app, and VPN cache, restart my device then I logged in to my tivimate account. It solve my problem.
Sup DR…
In tivimate (while in full screen)… hold the OK buttn, u should get a pop-up menu on bottm, youll see time off-set, u can fix 1 chnnl or make all them the same (scroll dwn)
hth… “_”
So when you clear data than you are starting from scratch meaning i need to put in all credentials again
Data clears evrything, cache just clears disposable stuff
Remember to use yor back-up when u think yor going to clear app… it’ll restore all yor info & changes
gl…
TY it was set to 0 rebooted still the same
U need to adjust it manually DR
Yes, but be careful if you clear data you have to have sign in again, and enter m3u url.
Well this solved my problem. You decide what you do.
report it to your iptv provider. they can fix it
Hey @DRGio Your problem could be strictly an iptv provider stream problem. Before you clear data on your players…put in a free m3u playlist like tubi or pluto & see if the problem is also there. Tubi below…
https://www.apsattv.com/tubi.m3u
You manually adjust the offset to sync the audio to visual. If this happens in all apps on your device then there should be an audio sync option in the device settings. But if just TiViMate then try the offset or, as others mentioned, try another playlist and see if those channels also have an audio sync issue. If not then as also mentioned, contact the playlist provider.
Syncing a Chinese movie, I don’t know what you would sync? That’s the whole fun of a Chinese movie… lol
How do I keep my device working to best performance? How to close background apps
Android - use Background apps and Processes list app. Available on your device AppStore.
What I will do is everyday clear system cache before turning off my device.
To close background running app you have to install fast taste killer app from RAI from TP or you can also try TP manual to shutdown background apps .
Fast Task killer
Turn off Background Apps
defsquid.com You can see and close any apps running in the background. Run a scan for malware. Run a cleaner and optimizer as well as remove unneeded apks. A nice little all in one app.
