Skeleton Crew v1.2 Build
Version 1.2 should be coming soon. Just waiting on it to be uploaded to the repository. Here’s the changes:
Removed Seren due to issues installing.
Viewtypes now resemble a Netflix type layout
Direct shortcut to RD authorization
Direct shortcut to Trakt authorization
Exit button now force closes Kodi
I’m assuming i do this with the Estuary skin rather than with the Xenon build skin enabled??
If so, there are two add-ons that i guess i need to do in the same way - one is for Venom, the other is for ???.
If i install Skeleton Crew 1.1 (or should i wait for 1.2 - it seems some ppl are having issues with 1.1??) will it overwrite The Crew ‘normal’ add-on i have installed in Kodi now??
I was getting Trakt errors pop up a couple of times an hour for ages, then had the issue with RD just crapping out. Reauthorised RD, opened both my Trakt & RD accounts on my tablet then everything was ‘hunky-dory’ - sooooooooooo, i don’t want to screw anything up when it’s working fine now (did i say how much i love Kodi & the add-ons, especially The Crew?!) The Crew sports section works very well and has everytime i’ve used it in 2 years. I’m not really concerned about IPTV - i have 2 providers at the moment & i get IPTV on some other add-on as well as an EPG (don’t ask how i got it - lucky that it was included in the Xenon build i guess)
Sorry for the longwinded post & thank you for getting back to me ‘PiratePete’ - mucho appreciated!
You can install it from diggz xenon but like jayhawks said, wait until Version 1.2 is released . Skeleton Crew has iptv and all the sports . Venom you’ll have to add on yourself but you probably won’t need it. Keep an eye out for the release of version 1.2 good luck :+1:
Solid adapting Jayhawks.
Having users only authorizing RD & Trakt once to cover more than one addon is great for the casual user or someone helping a non-tech friend or parent get up & running.
Seren used to be so good, but now it’s kinda a PITA. Good for you in eliminating one of your headaches.
No matter what build you use you can always disable or uninstall addons that you don’t like. Pimp your build to how you like it :cowboy_hat_face:
Version 1.2 is now live in the repository. Enjoy!!!
Thats my Saturday morning sorted!!
Thanks so much @Jayhawks659 :upside_down_face: I’m going to install it now.
What do you think of the changes?
Hi Jay,
Everything is perfect. Youve included everything that’s needed while keeping it simplistic and without bloat. Setting sub menu has debrid & trakt logins . Youve even included “networks” in the TV Shows submenu. I normally end up customizing builds like diggz xenon . Its a great build but I don’t need stuff like Arcade, music , trakt or the weather…the weather widgets is just something else that has to load up upon startup. Everyone has the weather on their phone screen. I’m waiting for my wife to get home. We’re going to use skeleton Crew 1.2 to watch the new episode of ******** :eyes:
Thanks for the awesome build :dizzy: Pete
Just got the latest version1.2 @Jayhawks659 and everything is running great. Love the upgrades and the new look. Excellent work. well done :v:
In the immortal words of Dean Winchester from Supernatural…
AWESOME!!!
I can not fault this build at all. The only things i had to change were the region setting for UK and the video player settings for surround sound (which i have to do as a matter of course anyways)
@Jayhawks659 you are a legend Sir.
Thank you for giving Kodi users what they have yearned for.
If we lived in Florida we would take you for a Beer!!
Thank you.
@Jayhawks659 you have certainly out done yourself sir!! Nicely done and thank you very much!!! Love the set up very nice indeed!!
:hugs::raised_hands:t3::clap:t3::metal:t3::confetti_ball:
@Jayhawks659 Impressive, very nice, has pretty much everything and anything and all I needed was 3 channels :rofl:…Light weight feel, Big Time build :+1:
I couldnt help it but I installed the Embuary skin because ive been wanting to have a look at it and I like it with all your hard work and my skin…I might be on to sumthin :joy: :joy: :sunglasses: :thinking: By the way any emby user might like this skin as it is designed to look like the emby client player :+1:
The beautiful thing about Kodi is you can do whatever you like.
I am struggling to get skeleton crew working. Maybe to much junk added to kodi 19.4. Should i do a clean install of kodi and skeleton crew?
Anytime you install a new build it’s recommended to do a fresh install, for exactly this reason. But if you aren’t ready to give up on your old setup yet and you have the storage space on your device you can download a Kodi fork and install this build on that to test it out first.
Well ive been in my once a year Kodi mood :rofl:…,And all I can say is there is no build any better than @Jayhawks659 's build, hands down. I suggest any kodiphiles to check it out. :sunglasses:
How do I set up the auto play feature in this build plz! I’ve tried and tried to figure this out but everything I seem to do doesn’t seem to be working out!! I had went back to TP’s set up auto play feature in kodi like I usually do cuz it works perfectly and that didn’t help this time!! I also tried using in the up next add-on and still nada :man_shrugging:t2:
Love this build it’s definitely my absolute fav by far!! So could somebody plzz help :pray:t3:
TIA
