đŸ”„ Shhhhh! These Fire TV Apps Haven't Been Blocked & Probably Won't Be
On firestick 4k I have sportsfire film plus mobiflix. Uk Turks. Sportzx. All working you just need to spend some time and do your research :+1:
Forgive my ignorance but are you saying the firestick 4k and 4k select are different. I tried loading tivimate and it would not. Can you help me with this?
The 4K select is the new linux based VegaOS and the 4K Max is the old Android based FireOS. TiVimate does not have a linux release. IPTVnator is for linux. Now this is based upon research and not my own experience.
If the so called “crap apps” are so bad, why are they in the TP tool box?
Because they’re popular. :down_arrow: What @SoloWarrior said.
Ease of use. Lots here don’t want to learn KODI or Stremio and like apps that are easy to install. Thus the crappy apps :rofl:
They aren’t. We don’t have any of those in the Toolbox and never have.
If it’s not spoon fed most won’t bother or the 3 per month too expensive for them.
I have 4k fire stick but I’m in the Troy point toolbox but it will not let me download stremio. The latest it shows is 1.9.12. Amazon really sucks. You see in picture that’s all it does.
@Slash1951, looks like you’re trying to download the 64bit version, it should be the 32bit version
That was the 32 bit not 64.
Alrighty then :confounded_face:, please disregard previous statement :laughing:
If using a VPN try disabling that temporarily.
Thank you @itzme anyway! :slightly_smiling_face:
Troy you were right you have to disable Surfshark for it to download. Thanks you sir!
careful @waingro be nice now
Looking forward to the setup video. Happy Easter.
You’ll love the AI upscaling on the AM9 Pro, it is much better than the Amazon AI
You made my day! I thought at first it was my cats but never remembered doing this. I didn’t LOVE IT thanks
The streamfire app works perfectly but the sportsfire doesn’t work for me unless I turn the VPN off. Although not as many as sportsfire, streamfire has a lot of good sports apps. I loaded them with an onn box.
