šŸ”„ Shhhhh! These Fire TV Apps Haven't Been Blocked & Probably Won't Be
Just back from holiday…feeling a bit down and your video cheered me up no end.
I have an older model Firestick which still allows sideloading and some of my friends do too.
QUESTION: Should we turn auto updating off on these devices? Will auto updating result in conversions to the Vega OS?
Vega OS is an entirely different OS based on Linux not Android and cannot be installed on older Firesticks. So no it won’t and can’t overwrite the FireOS but yes I would turn off any updating. The fact is those firesticks are ā€œTerminalā€ and will eventually not be useable the way we have been accustomed to. Amazon will still provide updates for about 5 yrs but I would not update until the ā€œexpertsā€ can see what exactly the update does and if it affects the way you use them daily.
Thank you!
I find Surfshark to be really finicky with some apps and iptv services, and that’s one issue that don’t have with lp Vanish, although I do wish that the kill switch was built into the app with just one click like Surfshark though
A few days ago I got the exclamation mark on my XCIPTV app. I can still launch it but should I uninstall and reinstall it? I have the FireStick 4K MAX.
Same here.
Where did you find UK Turks? Can’t seem to find it anywhere these days??
Try 587723 scroll down and you will see uk turks
i get the webpage not available message :face_with_spiral_eyes:
I went on earlier to check and it was all working then just checked 2 min ago all working
Fool I am…VPN was the issue…when i turned it off to check if it worked without…the kill switch kicked in. Turned off the kill switch and all is good. Thanks for the help!
Glad you sorted it
