Seren not working
Make sure your vpn is turned on.
Diggz Free99 addon is good. Troy has instructions to DL.
Cool…Also, Elementum.
Seems to be back… tested a few and they worked
Seems to be back… tested a few links
People… Stop auto resolving links and set your searches to terminate early after 20 results of your desired resolution are found.
Yep…debrid is back up.
Not sure what this means but it has been mentioned that the issue was related to Apks and not kodi.
Just checked my addons. All seems well.
No problem with my APPs. Sounds to me like it was a matter of not learning the best settings to use.
Well someone mentioned settings on apks. No idea what any of that meant.
You are smarter than the average bear… lol
Just to be a royal smart a**. You don’t do any settings in any APK, but you do in the App.
That’s a Royal Canadian Smart A**. :laughing:
Can you help me with Seren? I have followed all directions and install requirements and will not pick up my collections or any tract shows. Is there another source I might try?
Just making sure…
Kodi 21?
Seren Omega?
Rd account authorized?
Trakt authorized with Seren Omega (after you installed)?
Using a build or stand alone?
I’m using omega. Put trakt credentials in and rd also. When I install it shows tv shows and movies but will not show my movies or tv shows.
Also stand alone
Saw this article, it is a refresh of Kodi Trakt scrobbling and an addon it looks like towards the bottom. Might help.
Trakt TV on Kodi & Streaming Apps - Sync Your Shows and Movies (2022) (troypoint.com)
I dont use Seren exclusively but more as an extra addon. I saw just now on reddit people were saying a few month back that seren doesnt synch well with Trakt. Both before Omega and after.
Many here would recommend Umbrella as a good stand alone addon. I dont remember anyone complaining about trakt not synching.
There are a few other addons as well if you are willing to move away from seren.
I use a build so its a little differnt as i have a dedicated trakt category.
Totally agree with your Umbrella suggestion. Been using KODI for so long and have learned not to love any addon. They all do the same stuff and right now Umbrella is kicking some major A$$. Fast as Shi$ and the scrobbling with Trakt is the bomb. used The Crew for well over a year and it still works great but Umbrella with cocoscrapers IMO is the best working KODI Addon right now
Ok. So i checked with Seren and have my movies and tv shows synched. I’ll give a quick tutorial and see if this helps you. FYI, i had to synch this apart from the other addons. Usually they all synch together but not Seren.
First of course in Settings you need to authorize Trakt under Accounts.
Next, open the addon and select Tools and then Trakt Synch Tools. Then select Force a Synch with Trakt.
Go to My Movies or My TV Shows and you should see history in Finish Watching and My Watched Movies/Tv. None of the other categories worked for me but these 2.
Good Luck!
