Hi
I’m not familiar with the the procedure with the link you provided. I know it doesn’t work on the downloader. I looked around to see if there was an answer elsewhere in the replies. Would someone please help me with instructions. Thanks in advance
Hi sullee & yw in advance… lol
That url is a playlist
U need to dwnld an iptv player (tivimate,xciptv, smartrs) from Troys Rapid installr & enter that url into the Playlist- m3u plylist area perfectly, to get a big selction of free chnnls/progrming (pluto,stirr, music etc)
let us kno if u need more detail or if u need Troys app installer link
hth
Thanks much sketch
I’d appreciate you sending me the link to the app installed
Again thanks
No probs…
Put this in dwnloadr…
Might want to dwnload Unlinked app while your in the app installr, it has tons of apk’s, plyrs & tools
(Put in 12341234 to add a new library wait to load)
GL
Hey guys. Thanks to the op for the list. I wanted to know if I could be directed to a couple more lists just to have in case this one shuts down. If that’s a possibility which I would believe it is? You can have up to five Playlists right? Lastly, I have my gfs cable login for now so is this even necessary or should I just use her log in which is easier but I have to download more apps of course. I promise I didn’t mean to type this much buy thanks in advance for the help.
If you are referring to Tivimate. Then you can have as many playlist m3u as you want. You have only 5 subs you can use on your devices from Tivimate.
Thanks. Is there a way I can find some of those lists?
Prayers for your Wife
Go here and TP has a page also.
Hold steady, things will improve!
Thanks and sorry to hear that.
Best to the wife Miki
Thanks alot. I have pluto and tubi, I was more so looking for Playlists like this one maybe smaller and more so for US channels only if that exists. Thanks again.
God Bless Mrs. Miki !
Sorry to hear that, I would be interested in the list also. Take care Miki and wife.
Wishes for a speedy recovery will keep in my thoughts and prayers🙏
@Miki and your wife … Sending Caring Thoughts and Prayers
Then click on the link I provided, and you will see a few dozen m3u to download. I like this one quite a bit.
Playlist: https://cutt.ly/DSr95Combined
EPG: https://cutt.ly/DSr95Combinedepg
The list is exhustive, but a treasure tove of channels if you’ve got the time to pick through them all.
My problem is the major buffing issue with 90% of the channels. Real-Debird option is offered. Any suggestions would be very much appreciated.
Got it I thought the list was for Pluto I see it now. Thanks again.
