Since Cinema is no longer, I’ve tried Teatv, Beetv and even Cyberflix. They let me sign in to real debrid but when I try to watch something, no real debrid pops up. Plus do all of these have the annoying commercials?
Re authorize your account
Delete your devices in real debrid and re add them
Please go threw the guides.
I would also use something els with realdebrid.
We should add:
To delete your devices, you should to go to the real debrid website.
I can add it, i just assumed because you have to go to the website.
Might be a good idea…when someone (re)authorizes an addon or app, it’s automatically added to your dashboard. I haven’t found a way to remove devices without going to the website. Maybe there is, butI haven’t figured it out.
That’s exactly why i didnt have it in there as real debrid is managed by there website its kinda self explanatory. But i changed it
