Not getting any " paid " streams w/real debrid …tried to program my new 4K stick several times but no change…I have two older sticks that work fine but this one just gives me 6 free streams …I only have Kodi 9, The crew, and IPVanish ?? What did I miss doing
Make sure your real debrid subscription isn’t up. Depending on the thing you’re searching could only have 6 paid links.
This mainly occurs with older stuff. Don’t mention what your searching is what I ment, you can discuss your issues here.
I don’t know if I sent you a response to this…so I’ll try now…this is a new 4k stick that I loaded kodi 9 - ip vanish - real debrid and The Crew which all loaded properly … and which I have on my other older sticks, always give me up to a 100+ paid streams on a lot of TV shows plus…This 4K stick set-up is giving me only 6 streams on most of the tv shows which mostly will not work properly.
Thanks for your time
Are you saying the shows you watch normally give you 100+ but on the new stick the same stuff gives you 6?
You don’t normally have to do this but login into your real debrid and clear your downloads under downloaded.
Also if the crew and rd are setup properly you shouldn’t get just 6 if something els is getting 100 on the same.
Try re authorize your real debrid on the new stick.
Most builds I have used you sign into real debriid and traktv once. I have a build now that requires you to sign into each provder. What is your download speed?
Sorry about that Dracoo.Didn’t mean to ask the same thing you just did. I was writing my response when you answered and didn’t see yours.
Don’t worry about that, it happens, I do it alot if I haven’t refreshed. All good.
Well after clearing out the downloads and reauthorizing Real Debrid I now get zero streams …before doing these I have tried rebooting to factory setting twice with no help is possible to load Kodi 18.7 instead of 19 and see if that helps???
It almost sounds like your real debrid time is up or you are using a VPN that isn’t on their allow list.
My real de brid acct has 2 months premium on it and I’m using IPVanish which is what they recommend…so is in possible to use Kodi 8.
meant to say down load kodi 18.7
Going down a version won’t solve the issue.
Kodi 19.3 the crew and seren with rd. Try Uninstalling everything and reinstalling.
I will be putting in a new modem in a few days and I’ll try to get this stick to work,and let you know if I works…Thanks for your time
When you re authorize real-debrid make sure your IP Vanish VPN is off, once you re authorize turn your VPN back on.
I’ll try it , but IPVanish is suppose to be good to Debrid,Thanks
IP Vanish works very well with Real-debrid but when you registered for Real-debrid you need to register without IP Vanish on. So when you configure Real-debrid with a new addon or apk you need to do it without IPVanish on. Once configured back out of the app turn IPVanish back on and you should be good to go.
OK…I will give this try asap and I thank you for your time and info…
A post was split to a new topic: Real debrid and buffering
THANKS !!! This was the way … works great
Hi, have you got your rb set to 90 or 100?
