Real Debrid not consistently populating links
I am having trouble with real debrid. Links are not consistently populating in cinema and Bea. I am using a 4k fire stick. I have logged out of cinema and reauthorized real debrid in cinema. I have cleared the cache on the fire stick and in cinema to no avail because I’m sill not getting consistent links. Can anyone advise me on why the this happening and provide me steps on how to fix this issue I’m having?
Please do a search on this i can tell you this is posted.
Im going go give you 2 things you should read regarding real debrid. Also bot everything will be available in 4k links btw, especially stuff not out to stream or stuff in theaters.
Please see this mega cinemahd troubleshooting guide.
I’m having this same issue with BeeTV. Haven’t got a resolution yet.
Older under populated apps could be why. Rd has made changes to their api and web hooks and if devs havent updated their app its a possibility that would cause it.
Thank you all. I’m now receiving my links.
