Real Debrid - No Links Found
Every movie I try to watch it says no links found.
What’s Up with Real Debrid?
I set this up on The Crew as instructed but it’s not finding any working links.
Does anyone know how to get the free Real Debrid to work?
Thanks
When it is searching for the sources, does it pop up and show the “paid” and “free” sources in 4k, 1080p, etc etc?
Yes, it shows paid and free links but doesn’t give option to select free.
What add-on are you using to access the movies/shows?
Just looking through the settings on The Crew, here is a hypothetical…what if the “Debrid only” setting is checked (in playback tab) and then somehow the real-debrid and torrent providers list all got unchecked. So it could be trying to use the paid sources but nothing is enabled. I’m probably wrong, but like I said a possibility lol.
*There is an “Automatically adjust quality” setting in the media server under Quality Tab. Might be worth turning off and testing.
*Also under the Transcoder tab, you can turn “Transcoder Quality” to Maximum.
Double check to make sure your debrid account is active and paid up.
The Crew is the addon
How do I get to the “playback” tab and the settings you are talking about?
I’m using the “free” Debrid account.
I believe on the free debrid account only one source is displayed per search.
Tools, Settings: General, Playback…Make sure Debrid Only is OFF. Scroll down to Providers, Real-Debrid Providers on the left column. See what setting those are set at.
Real Debrid Providers are:
MYVIDEOLINKS (ON)
RAPIDMOVIEZ ON
RLSBB ON
DEBRID ONLY IS OFF
10-4…unfortunately the free providers are such a toss up whether they will work or not. Have you considered going premium? It is arguably the best deal in cord cutting, for what you get for such a small price.
I wouldn’t mind the premium but wanted to try out the free first.
If it doesn’t work how do I know the premium does?
Even if they hypothetically didn’t work on The Crew, there are SOOO many more apps that work with Real-Debrid. Worth its weight in gold.
Only thing I can get to work on The Crew is the “iptv”.
Most of these good apps are meant to be used with premium Real-Debrid, even though they have free sections and options. Apps like Seren is Real-Debrid only, but it is a very, very good source.
What app do you recommend for movies using Real Debrid?
And thanks for your help. All of you.
Best Real-Debrid Apps & Kodi Addons in 2022 (Buffer Free Streaming) (troypoint.com)
Free realdebrid does not offer you any links. You will not get any links to work with a free account. Its 6 bucks a month… worth it.
