On this link: https://synclerofficial.com/syncler-provider-packages/
In section for Real Dedrid how do I enter those links for that section to use those links with Syncler
Can anyone please help me with this
I have done the install but it doesn’t seem to find any sources
Follow the tutorial. It tells you how to add providers and which ones. I suggest having the tutorial open on your phone or tablet as you follow the steps on your Streamer. That way you can pause and replay any steps you don’t fully understand or have perhaps missed a step.
Well I don’t understand this the express provider package is grayed out
Delete everything and start over.
Are you trying to do the beta version or the older version?
No beta version and I am trying to do version 1.3.7.1
Hello,
The Syncler APK is having a Trailer Playback Problem (accessed through the “Browse Trailers” menu). This is a recent development, it had never happened (through years of use). This is the error message displayed in the application: “Video source isn’t working or incorrect time.” It is occurring right at the time of hand over to the playback app (which is SmartYube).
I re-installed the Syncler app last night, and the problem persists. BTW, this app is running on an Nvidia Shield.
Has any of you experienced the same issue? Any troubleshooting ideas?
Thank you!
Syncler has “SDebrid”, what it calls an 'Experimental Debrid Service" within its Accounts section along with the other three normal options. Anyone familiar with this?
I take it nobody knows what this is? I was just curious why Syncler has it in there, when I search I can’tfind anything about it.
Not familiar with it but it sounds similar to real debrid but free. May be helpful for older stuff but not to helpful for newer stuff so I’ve read on Reddit.
i hate to hijack this thread, but i cannot start a new topic at this point…
looking to see if there are any good “express provider packages” for syncler.
i had a good one for a couple years, but it stopped working within the last few days.
i tried the three that are on the troypoint site but those fail also.
the kosmos link works but, not as well as the package i had installed…
thanks
for any info…
jim
Are you pairing it with Real Debrid? If you are, have you seen the numerous threads about Real Debrid effectively shutting down as we know it? You can use Express but would need to pair it with a working Debrid or equivalent.
Thanks for the info…
i WAS using real debrid, i went to their site and everything look ok…
did a more indepth search and i see the posts now…
thanks again.
time to find another…
jim
Hello @WildBill see this for new Syncler setup for Beta and Premiumize.
I set up Syncler+ Beta with AllDebrid. The problem I’m having its not working with my Surfshark VPN on. Alldebrid fails to authorize and I don’t get any links. Does this set up only work with VPN off? Is VPN necessary here?
Greetings,
I’ve moved away from Syncler+ back to Kodi with just a few addons to my liking.
Cheers ![]()
Hi Troy and all the best for the new year!
Has there been a “falling out” between Syncler+ and RD?
My RD account is in good standing and RD is working perfectly on all my other popular APK’s. Premiumize is working well on Syn but RD (even showing the account is good) pulls nothing at all even with Prm disabled.
Just wondering what else it may be. if you or any of your knowledgable group have any ideas, please let me know.
Thanks a million for your site and all the help it provides to everyone, cheers
