Install and give Syncler beta a run. You’ll see vast improvements with RD.
Though if you have PM, and it works, maybe not such a big issue.
Thanx @mthr1, I will give it a try.
IMPORTANT UPDATE:
After posting I hunted down as much info as I could about my Syncler+/RD problem and found (on Reddit) that there is an update to Syncler+ (1.3.8) which fixes the RD problem, I did it and BINGO, it all works perfect now.
It’s quite easy to do: open Syncler Installer app and hit download, then, be patient and wait through a few black screens and the update will automatically be applied to your Syncler app, nothing else has to be done. Following that, make sure your RD account is good and setup properly. I am getting great feeds now. LOL, i shold have thought of that earlier. I hope this helps others who may have had the same problem, cheers to all!
If I had seen your post I would’ve mentioned that the RD api change broke all apps and addons when using RD.
Which needed those apps and addons to be updated.
The quickest updates came from the Kodi devs and the Stremio addon devs.
The Syncler updates did eventually arrive but the stable version fix did come a week later after the beta version in the beginning of December.
At least you have the fix now.
Ah - yeah, I forgot about that update. I just foolishly assumed you were already updated.
Actually, the most current update is 1.3.9.2.
Though since I’ve been running both the 8.2 and 9.2 updates, I’ve come across the bug where each view, no subsequent view will bring up any sources.
This is fixed by exiting out of the program and reopening. Then it happens again.
Annoying - and maybe long term fixed with a reinstall, but haven’t had time to test.
It didn’t start being buggy right away after the update - about 2-3 weeks after.
Don’t sweat it! I foolishly assumed it did background updates lol! Maybe i’ll hold off on the 1.3.9.2. update for awhile since it’s bugging but i’ll keep checking for an update to the update : slight_smile
Thanks for having responded , it’s well appreciated, cheers!
The v1.3.9.2 update fixed RD causing Failed to prepare errors in v1.3.8.2.
But if it’s working for you then no need.
Seems to be holding up for now. Thx for the headsup!
The Syncler dev stated on Reddit that the stable version will only receive critical fixes until beta is stable.
See here.
https://www.reddit.com/r/SynclerApp/s/Ku2qq5TTtg
Got it! Thx
