I’m using Weyd with RD. Is there a way to watch a link that isn’t RD? Sometimes I find a show that has links but not RD but they won’t open.
You might get an answer that is helpful if you give a bit more info. What app are you using this in?
I’m using fire stick and formuler z pro max…neither will pull up a link that isn’t RD. Which I’m thinking I have some setting on that will only work with RD but I’m not sure what to look for
Not the device. What APP are you using? Stremio? Kodi? As this happens on two different devices and two different OSs, I suspect you are missing a setting in the app you have weyd and RAD authorized in.
Weyd does not provide free links. You need RD, Alldebrid or premiumize Account , If you have them, go into settings, accounts and log into the service And then you will pull links from a different provider.
I’m sorry is Weyd my app? That what I was asking in my original question.
Ok gotcha… I only have RD so that makes sense. I just thought I would be able to link on a link that is provided that it’s RD but it would buffer.
Lately I did notice with RD that not all links will play perfect and I have to pick another one.
weyd is your all-in-one solution to TV Show and Movie tracking using the Trakt API.
Real-Debrid is a subscription-based service that enhances the streaming experience by providing access to links from various file-hosting services.
