no, i am not using a vpn
hip, hip hooray! i just got pov to install onto my shield.
i only have real-debrid, and authorized real debrid.
also clicked on enable real debrid, butâŚ
when i search for sources to stream a movie, error message says no results found.
what do i need to change in settings to get real debrid to work?
I am not at my device but I think it is my services in settings there are two itâs the second one.
i figure out how to get real debrid to work in pov.
thank you to everyone who responded to my situation and offered advice on what i shouod do.
thanks to everyone , again
Thanks for your help but still i couldnât install Kodi on my Android TV. Cannot connect
@Mira are you just trying to install the Kodi application? If so, may I suggest that you watch this tutorial from one of our highly respected Insider members, Jayhawks659.
OH! and welcome to Troypoint Insider!
If using vpn turn it off while downloading whatever you want. Then remember to turn back on to stream.
You say the followingâŚ
âi have tried 4 times and says kodifitzwell repository addon installed, then click on install from repository and says could not connect to repository.â
It doesnât sound like you installed the ZIP before trying to install from depositoryâŚ
After installing the Kodifitzwell depository, go to Addons and âinstall from ZipââŚonce thatâs done, âinstall from depositoryââŚ
Itâs pretty basic but maybe you skipped a step?..
The repositories are down both.
Working for meâŚ
Click on respiratory, zip file is gone. Iâm using 19.5 because of permissions. I havent tried other device with 21.2
I am using latest kodi version so not sure tbh.
Yeah just checked 21.2 zip is there. He also has a new module for scrappers but I donât see it
Dev has just added torrentsdb to aiostreams. You can see these in sources and enable them along with any others you might need.
Also the Rd+ and Alldebrid+ are still available in My services if you use any of those Debrid services.
Also added magnet scraper. Differently one of the best out there. Used to be the awesome venom
Didnât see that on the POV change log tbh.
Funny thing not many people read those lol. Yes I believe it was in lastest driadis update log. Thing is you canât change it like umbrella. But I suggest opening magnet scraper and turn on most of them because by default thereâs like 2 that are on
I usually read them and in POV change log I didnât notice a mention of Magneto scrapers. Maybe they are used in the Dradis add-on
Yes like I mentioned doesnât allow us to change module itâs aka venom scrappers he or she lol by default doesnât use all differently about speed
