Pluto EPG not updating?
Is anyone having success with the Pluto tv and the EPG for that ? Seems to just have a blank generic description of the channel and nothing else.
Like with the most of IPTV its been hit&miss past few days, used to have full EPG now its no information on all.
mine never has, I downloaded pluto app and its channel guide works fine.
Probably changed the EPG address. Are you using the app or trying to use it through an IPTV player like Tivimate?
PlutoTV epg is working fine in my Tivimate.
It is working today after update. Weird.
Are you referring to the app or the m3u?
I just checked my Pluto m3u and it looks fine. I am updating the epg, but in Tivimate you can’t update a singular epg. So I have to wait until all 20 of them are completed. I did check several channels and the epg seemed ok. Some of the BS channels like QVC only have a short generic description, but all the more popular channels seem to have a more detailed epg.
Using the app to get more detailed info about a program you have to either long press on your “Select” button, or click on the program and then click the select button and scroll over to the :information_source: icon and click it.
