I know that this topic has been visited before, but i have now upgraded to the 4k max and cannot find older related details on partitioning a flash drive. Thanks for your help
Ask Miki…I don’t think that partitioning a drive for a 4k Max is going to do any good. You must either use the extra room for content or apps, not both.
Elgin is correct. It’s a shame that Amazon made adding storage to the firestick 4K Max easy, only to limit it to either apps or recording but not both. I’m getting a 3rd gen cube asap and then I can add a large drive and format it ntfs and eliminate the fat32 size limitations.
That’ll be a great device!
The question is whether that extra storage on your cube will work for both storing apps & recording content.
From what I’ve heard it can be both. But with the cube having a good size internal storage I would put my apps there. I presently have a 16GB sandisk 3.0 and can’t even fill it up with all the apps I have and test. The large external drive formatted to NTFS would take a ton of recordings, depending on the codec of course. I read about 1 guy that attached a 1TB drive. Now if anyone wanted to go that route I would talk to @TXRon and ask him how to set up something like a plex server. More versatile I suspect.
WOW, 1 TB would be overkill!!!
Unless somehow you were ripping 2140P blu-rays or something.
Exactly. I’m like OMG are you setting up a video library?
