I’m trying to set up an old 19.98 Walmart Onn 4k dvice (not the pro) that I haven’t used in a long while. I have a 60g thumb drive on it. I moved my apps onto the thumb; but when I try and add another app, like remote ADB to it, it says"Not enough internal storage". When I look at the storage, it has no apps installed on the internal. It says 1.3g of 4.8g used. How do I fix this?
Never heard of 60 gig drive?
Not very helpful
If your onn device is the original one, this video should help
That is the amount of space available on it. But thanks for that so helpful comment.
It doesn’t help, because, as I said, when I go to download remote ADB, I get a message saying there is not enough room, even though all the apps are already on the thumb drive.
The supercharge video link doesn’t seem to work. This one could help.
Except, like I said…I cannot load remote ADB, because it says I don’t have enough storage…even though I already moved all the apps onto the thumb drive. I have over 3g available on the internal storage; but it still won’t let me install any apps.
I understand the issue, but I’m at a loss what the solution is. I just noticed the link above didn’t work, thought it might be worth re-starting the process and see if it fixes whatever weird issue has occurred internally.
The link is working now.
