When setting up ONN box i try to bypasd putting in phone number but wont let me. I go to my son’s home and it doesn’t require a phone number to set box up. Any ideas?
Are you setting it up with a Google account? I dont remember putting my phone # in but logging into my G account.
Or are you trying to setup without an account?
Trying to set up with generic account. To be hid so to speak. Just wondering if my internet is blocking me
Not sure if thats possible without a phone number but i am sure someone here will know.
Good luck.
I am able to do it while connected to hotspot off phone. Just cannot do it on my internet.
Is it possible the phone’s hotspot is giving a phone number to the streaming device? Not necessarily your # but one associated with the hotspot signal.
I would imagine that signal has to be identified somehow back to the phone.
I really dont know. Just asking.
As far as I know you need a Google account to set up the ONN Box. As a work around you can always create a fake Google account then you will have a burner gmail email address you can use when setting up the box
Right but do you need a phone # for the fake google account? I never set one up. Dont they need verification of some sort?
I have set several up with fake gmail accounts eith no phone number being entered. Just starting happening today.
I set up a G account and loaded onto my Onn 4k that was factory reset. It never asked for my phone number. I used my home wifi.
At what part of the process is it asking for it? The only time i saw mentioned is when i put the email adress in. It said enter phone number or email.
At that time i use to just go past it but now it wont let me go past it
Sorry but i dont see what you are seeing. There was no place i needed to get past for a phone number. I entered the Gmail address/password when prompted and it loaded up.
This is new to me so i am probably not understanding correctly. I only added my actual account in the past.
Maybe there was a software update that changed this?
Hopefully someone else knows better.
I have an ONN box but it never required me to input my phone number…? Where exactly are you seeing it? Does it ask you for an email address first?
I set up oann box and used a burnner gmail with no phone needed
Hope this helps
Perhaps two factor authentication is selected?
I Hotspot off my phone with vpn and had no issues with phone number was able to just skip that step
How about setting up a Google Voice number. It sure does come in handy.
Apparently there has been a major update on ONN boxes. I brought one back from America 2 weeks ago and went to set it up but straight away i got a region locked message which i can’t get past.
Reading up about it many people outside of the USA are now getting the same message, especially after a box update. I am in the UK, does anyone know of a simple solution to getting around the region locked thing?
Have you tried a VPN?
As Miki said, if you have a VPN you should be able to change your VPN server location to somewhere in the US.
