I bought an ONN 4K Pro streaming device. I installed a few apps with no problem, but when I installed Launch Manager and Wolf Launcher, the device is now on Wolf Launcher and only showing all of the apps. However, nothing works. Nothing will open, I can’t to the Home page, etc.
Any advice?
Have you rebooted the device? If so you might need to disable the launcher and try again.
The suggestions from Thottlejockey are the steps that I would also suggest.
Beyond that you could clear everything and start over without the launcher to make certain that the basic stuff work well.
I can’t get it to open any app or get to Home to disable it. How do I reboot it with that happening?
That is what I have been trying to do, but I can’t get any app or anything to open. The only thing it will do is move up and can’t get any app to highlight to open.
How can I clear everything? That is what I am needing help on.
I finally got it off the Wolf Launcher screen. You have to hold the Reset button down while plugging in the power source.
Honestly, I stopped using launchers awhile back. On the FS, I did but the Onn, I did on one but they seem to be more problem than they’re worth. Too many people have also said it broke their devices although I never had a problem. I hope you get it all worked out.
Yup I tried using Wolf and Projectivity Launchers and both Bricked my ONN. Had to do a hard reset 2x like you. No Launchers for me
My problem now is that when I go to the ONN box, nothing will come up on the screen.
That worked. Thanks. I have reset my box to factory settings and will proceed to installing the apps I want to use. Thanks again.
You can’t put AOSP launcher on a ONN can you ?
I would’ve thought so because the Onn runs Google os…
Sorry I should’ve stated that I am running AOSP but for me a launcher is not at the top of my list of features.
I don’t know. I am not that tech savvy, but I did reset it and installed everything without a launcher.
Wolf Launcher is a modded pirated version of ATV Launcher Pro . Install the new and updated ATV Launcher Pro and you wont have any issues.
Bertonumber1
I’d skip the launchers. Go to Settings, Accounts, and choose Apps Only. It will turn off all the ads and stuff and leave you with the hero image at the top and icons for just the apps you want. That’s it. For me, there was no other reason to use a launcher.
That is what I did.
