šŸ† Onn 4K Plus Review - New $29.88 Walmart Android TV Box
First place I went, don’t see any place that says message? Trying to PM someone? Miki, I’m not a patron,I’m guessing that’s why I don’t see a place to message you, one a day I guess. Bought an Onn Tv 4K pro. Set up no problem loaded some things. Having issues w some bugginess, so I restarted, now it won’t reconnect w WiFi? All my other devices are working fine, iPad, phone, firestick. Did all the steps, restarted router, modem, forgot network etc, unplugged. Nothing. Again setup was easy, I have surround sound, connected fine, vpn installed, apps that I was using prior, Kodi, etc. Not a good start. I’m not a fan of google, haven’t used search, gmail etc for years! And then there’s stremio, w no links. I’m at a loss. I know you want to help and have in the past. I appreciate all you’ve done. This is my one response today! Ready to take Onn 4K back.
Use the site search :magnifying_glass_tilted_left: and search for ONN not connecting to WiFi. Lots of posts
As Miki suggested, doing a search may help you resolve your connectivity issues.
To get you started, here is a thread that might help.
Restarted for 3rd time fixed it. Set up stremio on both firestick and Onn 4K acct w proton.me All looks good. No links and not able to install torrentio. Also any way to change volume control on google tv remote to continuous when you hold it down. Followed all the checks, no luck. And the difference in volume between firestick and Onn is large, swapped hdmi ports to check, same, firestick is substantially defaulted louder. Checked settings and volume. Because I get one response, I’m asking multiple ?’s Sorry.
I am surprised @Miki didn’t mention that if you aren’t a payed member you can’t send messages, I use to be able too before the recent restrictions but no longer.
Trying to back door this, I can receive PM but a response is the same as a reply, one or the other per day, not both and I can’t initiate a PM.
Glad to hear that you are getting it figured out. One question, you refer to ā€œproton.meā€. Are you meaning ā€œPremiumize.meā€?
As far as the remote issue, check this youtube video.
Lol. I wondered the same thing as proton.me is one of the e:mail alias settings.
proton.me iz short for yourname@ protonmail.com, they made a big deal out of shortening for you :thinking:
But does it help with streaming?
Not that I’m aware :person_shrugging: of, just an email address….
@itzme oops! I meant more as silly thing. Just me being goofy.
All good :waving_hand: @JerryJ , I was thinking that but wasn’t sure so I posted anyway :laughing::laughing:
Had an Onn 4K Plus about 3 weeks. Audio is now choppy. Changed to 1.8 power supply, no joy. Doesn’t seem to be any customer support. Suggestions or just return it for another?
Assuming that you’ve tried rebooting the device? I’ve had sound problems with my Onn devices and rebooting always fixes the problems.
No joy, even changed power supply. Put older Onn 4K on same HDMI, worked fine. Problem seems to have started after an update, maybe issue downloading it? No customer service so I’ll take it back tomorrow and trade it in.
yes @Laynet , seems the Onn boxes(not ALL of them, but some)-Plus or Pro-can have little glitches, and what @TROYPOINT mentioned is true for some people, just not everybody. i’ve have volume control probs in the past and my trials at overcoming that did’t work, and one day they just seemed to work it out on their own, go figure rite??
And on a different subject….:birthday_cake: :tada: HAPPY ANNIVERSARY TO YOU :confetti_ball: :balloon: !!! Just don’t let your cake sit around unguarded to long….some of us(and you notice i’m NOT mentioning any names) get a little cra cra when cake is involved
Same here one day the volume didn’t work on any apps, so I rebooted and ended up switching hdmi ports that my ONN was plugged into my tv and everything started working again.
Congratulations @Laynet for 4 yrs of TP participation. Your Patron participation has helped us all. Have a buffer free day. Fingers crossed for many more to come.
Might also want to try factory reset and see if that fixes the problem. Something bad may have happened during update.
