I do not use Bluetooth for anything to be honest. I use a Vizio soundbar with a sub woofer connected to my TV with an optical cable. With the Onn 4k Pro, the sound is very good. No Problems at all.
Welcome aboard…![]()
What connector do I need to add Ethernet cable ONN 4K Plus
I use bluetooth earbuds and headphones with my ONN 4K and FireTV Cube and they work fine. I’ve not set up bluetooth speakers though.
That’s a me to, anyone know what I can do with these old Mecool streamers. I have never been able to link them with Google for remote assignments, I was told a new OS from Mecool was coming that was two years ago, my new 4K ONN pro and plus are now my best and fastest streamers yet.
Hey @jimmyjay1884 have you seen the new category Troy created, it fits you perfectly….![]()
Hey Wizzard, unfortunately your information is incorrect correct. I had mentioned that I purchased 3 x ONN 4K Plus boxes in the USA. This model is not available in Canada.
These three models are on the shelf in Canada. Feel free to check Walmart.ca Please note for a long time you could also get on from Amazon but they were different and not what I bought in the USA. The pro is the clear way to go for all the obvious reasons.
$38.98 Onn. Google TV Full HD Streaming Device, Google TV Voice Control
About this item
Full HD resolution
Easily cast your photos, videos, and music with Chromecast built-in
Ask Google to control your TV with your voice
Access movies and TV shows from platforms like Netflix, Google TV, Disney+, MAX and more!
Easy to setup
Connector type: HDMI, Micro USB
Wireless technologies: MIMO WiFi
Audio features: Stereo; Mono
RAM memory: 1.5GB
$49.98 Onn. 4K Streaming Device with Dolby Audio & Fast Wi-Fi, Google TV Voice Control
About this item
4K UHD resolution TV streaming
2 GB RAM with 8 GB Storage
WiFi: 2.4/5GHz 802.11 a/b/g/n/ac MIMO
Compatible with Google Assistant
CPU: Quad-core Cortex-A35, GPU: Mali-G31 MP2
Dolby Audio
Fast WiFi
Input: AC 100-240V, 50/60Hz, 250mA max; Output: DC 5V/1A
Google TV OS - easily setup with your Google account
$74.98 Onn. 4K Pro Streaming Device with Google TV Hands-Free Voice Control & Dolby Atmos/Dolby Vision
About this item
4K Ultra High Definition resolution for stunning picture quality
Powered by a Quad core Cortex A55 CPU for smooth performance
Equipped with a Mali G31 MP2 GPU for enhanced graphics
3GB RAM with 32GB storage for ample space and speed
Supports Wi Fi 6: 2.4/5GHz 802.11ax for fast and reliable connectivity
Includes a USB 3.0 port for easy file access & Features a 10/100 Ethernet port for wired internet connection
I think they were talking about the 4K plus it has 2gb ram and 16gb storage.
Compatibility – U.S. and Puerto Rico Only
Premium Cinematic 4K Ultra HD Resolution – Enjoy stunningly clear and vibrant 4K visuals for a truly immersive viewing experience
Google TV for Seamless Entertainment – Effortlessly browse and discover content, all in one place
Your Favorite Apps – 700K+ movies/shows, 10,000+ apps including Netflix, YouTube, Disney+ and 800+ free live TV channels
Voice Remote with Google Assistant – Easily search for shows, control your TV, and get answers using just your voice
True-to-Life Visuals & Immersive Sound – Powered by Dolby Vision and Dolby Atmos
Immersive Dolby Atmos Audio – Enjoy rich, multidimensional sound that brings your entertainment to life
Impressive 16GB Storage – Double the storage vs the onn 4K model so you can download more apps, games and content
Smooth App Performance – 2GB RAM helps make navigation faster and multitasking more seamless
Blazing Fast Wi-Fi 6 – Stream seamlessly with reliable, high-speed connectivity for smooth playback and less lag. Wi-Fi 6 (2.4/5GHz 802.11ax) or a USB-C port
Quick & Easy Setup – Get started in minutes with everything you need included in the box
Included in the Box – 4K Plus Streaming Device, remote control (2 AAA batteries included), HDMI cable (3.28ft), AC adapter, adhesive tape, Quick Start Guide
My main TV is a wall mount with wires hidden by snaking them between studs. If I read the charts correctly, I can use the power cord for my old fireTV stick to an Onn Plus but not an Onn Pro. In some cases, that would be a good reason to go with the Plus rather than the Pro.
That won’t work as plug and play.
The Firestick’s power uses a mini USB end while the ONN Plus uses a C USB end. I don’t know if the power requirements are similar either.
You’re right! Sorry, I though I saw that the Onn Plus used a micro USB plug. I know I could buy an adapter to change the USB C end to a USM mini for about $5. I’m pretty sure both power adapters out put 6 V. It’s a real pain to change any input to my TV without removing the set from the wall, and that, in itself is a hassle!
Just note that the firestick cable terminates in a micro-USB, not a mini-USB (different plug altogether). So you’d need a micro-USB to USB-C adapter.
Brain fart on my end.
On a similar matter, it’s not just if the voltage matches. It’s whether the wall brick can supply the required current.
4k and plus are 5v, pro is 12v
I have a brand new onn 4k pro still in box. Do you think I should set it up and trash the firestick? I know you said you don’t like firesticks.
By all means the onn box is much better imho.
That’s interesting, and highly unusual. Good catch!
