The oath just stopped on me addon dependency keeps failing . Any one else having problems ?
Yes. Me too. Oath is. Great Addon. I hope it’s temporary
I am currently using Oath and it is working fine for me.
Strange. It disappeared from my Addons & when I tried to install it again I got an error message after I hit the install prompt. Tried several more times, same error message
That is strange. I have been using Oath on and off all day without a problem. I am using Kodi 18.9 and Real Debrid.
That is what happed to me .was using it ,was working then went for next show and it was gone. It’s still in file system . Tried to re install as it was gone from my addons . It keeps failing the re install
I am on kodi 19.3. It shouldn’t make a difference
I use the kodi 19.3 and no Real Debrid
I don’t use real debrid either. Will wait and see. Using a Nvidia tv
It shouldn’t make a difference, but sometimes things just fail. I would try to totally uninstall Oath and then try to re-install it.
My oath is gone …I am trying to re install from depository. I keep getting fail addon dependency
My Oath is gone, Kodi 19.3 and Real Debrid
Dminor9 are you on oath as we speak .And it’s still up and working for you - running Kodi 18.9
Ok thanks if it doesn’t come back I can install kodi fork 18.9 and try to install oath on that version
Just downloaded 18.9 fork and installed the Oath. Problem solved. Lol
Download 18.9 fork. Oath installed with no issues. Thanks
Ok I just put in fork 18.9 and addon oath . Every thing is working
Opened Kodi tonight and Oath was gone. Tried for last two and half hours to reinstall using all the different suggested fixes and nothing has worked.
I got it running ,only by using 18.9 fork and install oath .
Went back to 19.3 and it only loads up to about 22% as its goes so fast and fails . So it’s out for now
Watching now on 18.9
Glad it is working for you all. Happy Streaming!
