Oath addon not working
Just went back to 19.3 and got updated now working :sunglasses:
Same thing happened to me . . wondering if I’ll have to re-add all my Fav’s when it comes back on line.
Just disappeared . . 19.3 and RD . . won’t re-install.
Hopefully I won’t have to re-do all my Favs . . what a PITA that’ll B. ;-((
Switched 2 THE CREW 4 the evening . . .
The good news once I got the update it worked and favorite where all there
Did U have 2 re-install the add-on?
I haven’t received an update yet.
I did remove it and reinstalled it. Didn’t seem to matter. Did the dependency’s one at a time and disabled Crew as there seem to be one that was using it . Once I did that and installed them one at a time till there was none left to do I hit the ok and it was back in my addons for video like it always was. I just went back and re enabled Crew. Back working like it should.
Disappeared and dependency failed. Cleared the kodi cache and reloaded from repository and worked great.
The Dev made a mistake when updating and sounds like it’s fixed for all now.
Clearing the kodi cache and reinstall from zip, then repository worked for me.
Will need to try that next time. What is the fastest way to get to where to clear the cache on kodi
mine is working but not all that well it does not get as much as it use too one thing I need is a source to down load the 19.5 kodi and that oath I hear does not work on that one at all
