NVIDIA SHIELD Android TV Pro Streaming Media Player, why is it rated so highly?
Ok have both and they work very
Does it upscale live tv on tivimate.Just 720 or does it upscale 1080 to 4k also
What exactly does Avi codec do
It’s just a newer type of compression. Smaller file sizes with less data loss. Makes streaming higher quality videos easier because it requires less bandwidth.
Yes, if the video can be upscaled.
Yes, it upscales TiviMate and 1080 to 4K.
Only if you have a 4k tv otherwise 720 to 1080
