đŸ“ș Norofire App Installs Both Sportsfire & Streamfire - Fixes Fire TV Blocking Issues
Same here both apps all working well
total virus flagged sportsfire with many issues
I’m on Spectrum and it worked fine
Search online for the apk copy to a usb flash drive and install it to your box that way. I don’t have an ONN but it works fine on my Android HK1 box. Give it a try, I also did sportsfire and they both work fine.
Use norofire for those 2 apps. I did. Rece lived no problem
I installed norofire onto a firestick and when I try to install either sportsfire or streamfire I get this error message. It won’t download either one and I have install unknown apps turned on
Delete previous apps an clear cache an clear data on downloader
Downloader code 3255605 for Norofire no longer works. It spends a few minutes “Reconnecting
”, then says "It is trying to reach http://get.norofire.link/download/norofire. It eventually times out saying “Webpage not available.” What’s up with that?
Use the unlinked app type in FIRESTICK then scroll down to sports apps it’s there I used it yesterday
I removed the old downloads. Cleared the cache and data of Downloader. Put in this new code. It will not download if I click the first link that says Download APK. Nothing happens when I click that link. If I do the media back up link (the second link on Norofire’s page), Norofire downloads, but then I cannot get SportsFire or Streamfire to download. I get a Downloading Failed notification.
I appears that the server used by norofire to supply sportsfire and/or streamfire is offline presently. (I tried 3 times install sportsfire over the past 2 hours).
I was able to download sportsfire from https://sportsfire.org, however, after successfully sideloading, the app was unable to connect to the sportsfire server.
Streamfire is working fine at the moment.
Yeah i got the same yesterday. I contacted them on Telegram but no reply or fix yet.
Streamfire is down for me right now too.
Hope it’s temporary but only time will tell.
Exactly what’s happening with me and why I came here. Was hoping someone knew wtf??ugh.
Sportsfire and Streamfire are gone now regardless even on my fire stick???
Me too uninstalled tried to reinstall, Noro installs but fails to install Sportsfire or Streamfire I can get Sportzx but I prefer Noro, simple, Sportzx has to many links that don’t work
Haven’t been able to get any channels on Streamfire or Sportsfire for the last 24 hours (installed on Fire/Onn devices at 2 locations - with or without VPN). installed from NoroFire. Anybody else having this issue?
Same here i use Sportzx more than sports fire
both appear dead at the moment
Yes.
Its been discussed already here:
Let’s hope its short lived
