📺 Norofire App Installs Both Sportsfire & Streamfire - Fixes Fire TV Blocking Issues
All good here, I think it’s AT&T internet. They block a lot of traffic!
If you are having issues reach out to them on Telegram. They respond and fix issues.
Its under the Sportsfire name but they also respond to Streamfire issues.
Sometimes that happens to me period. When that happens, try putting on a v p n even a free one like proton, it seems to work then.
hi used mine yesterday watch hibs v celtic with no problems, you could uninstall it then reinstall and clone it .
My Streamfire is still working for me.
Mine isn’t. Mine now has the Firestick comment that the app is no longer permitted and I need to remove it. Ugh!
It seems that Amazon has block the app. I received a message that the app was disable due to security issues.
Anyone have a code for a working one? Firestick keeps flagging and deleting it.
5709452
Seems like both Sportsfire and Streamfire are gone now or blocked. Spectrum notice came through as app disabled because it has been identified as exhibiting potentially unwanted behavior. Tried the code and no go. Same message. Bums me out as it was the only place I found to watch F1 racing.
Not working
I have Spectrum Internet and mine is working fine.
Have you used a vpn?
Always. My daughter got the same message.
Code works fine just tried it
log into your spectrum app on your phone or through their website and disable the security suite.. spectrums version of Googles play protect. will block all kinds of sites and apps
The following was copied from their Telegram message:
App Blocking Solution
We have noticed that some apps are being blocked. There is a quick solution to resolve this issue.
Before starting, please make sure you have downloaded Streamfire APK v1.2.3 on your device.
If the APK file is not available, you can download it using the Downloader code: 6647940.
After that, please follow the steps below:
1. Download App Cloner using the download code: 6332051.
2. Open the App Cloner app.
3. Click on the “+” icon located at the top right corner.
4. Grant permission to access your files and folders when prompted.
5. Select Streamfire App v1.2.3 (already downloaded on your device).
6. The cloning process will begin and may take up to 5 minutes.
7. Once completed, open the cloned Streamfire App and start using it.
We recommend repeating the above process and cloning the app multiple times. This way, if one version gets blocked, you can immediately switch to another cloned version without interruption.
If you face any issues during the process, please let us know.
The instructions seem a tad inaccurate from my perspective. You don’t download an APP you download an APK which is an app installer. So should you be installing the app using the downloaded APK and then cloning, or clone the APK? Inquiring minds want to know. :face_with_peeking_eye::wink:
I plead ignorance. I just copied and pasted. Lol
Oh that wasn’t a negative comment aimed at you @JPM69 I knew it was a copy and paste and I apologize if it came across that way. I am just getting frustrated these days answering countless questions in an effort to resolve issues for users simply because ppl that put these instructions out there do not care about accuracy or assume that everyone that reads them is an advanced user with full knowledge of the process, who by the way, don’t really need these instructions.
Streamfire working good for me
