No Stream Available (again)
@Scotina58
Welcome to our community.
As a newer user I’d suggest looking at every thing troypoint has to offer for this info and guides.
Your first stop should be here: Mega kodi guides.
Secondly free links come and go, I highly suggest q real debird account, that will stop the errors you are having.
I have a realtor Bret account here for a long time this is the first problem I’m having after years of streaming it’s weird can’t quite figure it out. Are you saying I should delete the grand house build?
@Scotina58
Yes, then follow the recommendation from @anon36991227 above.
Should get you going.
@Scotina58
I’m not suggesting to delete your build. I’m not sure which one you are using.
My suggestion is to go through that guide. Plenty of updated builds that work with 19.3
What version of kodi are you on?
Most builds updated to 19.3. I suggest a addon if you have issues with builds. The guides in that topic are enough to get you going.
Thanks, 19.3 I updated real debrid and downloaded the crew. It’s working. Thanks sooo much
Reinstalling everything did solve my problem but I use a build so in my case that wasn’t the problem.
Uninstall and reinstall to updated version.
No stream available on anything that is on Paramount Plus or AMC+
