I have a strange problem wit the sound with tivimate. If i ckick on tv shows or kovies i watched on tivimate before, i stilk get the sound but if i ckick on any shows and movies i haven’t watched before, then no sound unless i use external player . Please let me know what the problem can be .
It cannot bf cables as the alreay watched shows are working. If i check them all on other players, they also work. In tivimate, if i select external player, it works. I cleaned up the cash.
Its strange as of why not the already seen movies in the app but just the new ones?
Ok, but please check that setting and see if in fact it is enabled and some update or such changed it. Pretty odd ones you watch work and new ones don’t. I’m doing a bit of searching now to see if anyone has had the same issue.
If your using your iptv vod service and the video hasent cached it sounds like you need to check your internet speeds and tivimate buffer size. If you have good down speed increase that. When selecting a movie puase it for 10 seconds let it buffer and sync up a bit.
I uninstalled and reinstalled the tivimate and no sound again. As fior the external player, only works with VLC. I thought it might be related to my tv box but it is a quodcore with 4gb ram Any thought?
Sorry TTM. I’ve used TiVi on an Onn, KM2, 4k stick, and the Max. All without issue. I can’t think of any setting you should change. I Just enable the audio pasthrough and make sure your stick is plugged into the ARC HDMI port.
