Paid up on Real-debrid until December. Logged out logged in. Tried three popular movies that I’ve seen in Cinema hd, which have several R.D.Links. Any thoughts? Thank you.
Make sure these links are actually the movie you think they are. Many, many, Cinema links are not what they say they are.
Thanks. I actually watched the movies in cinema hd. I was setting up mx pro in bee tv. Wondering why I wasn’t getting a bunch of rd. Didn’t know if oters might be experiencing the same problem.
BeeTV can be pretty slow. It will load free links initially and then start loading RD links and more free links. Wait a couple of minutes to see if you are getting the (different color) RD links.
Thank you. I’ll try to be more patient.
Please forgive my ignorance, but I am not sure pin or save your post, for my future reference. Thank you
You can “bookmark” this page/thread/post and name it so you can always refer back to it.
