Newbie needs help
Hi I have been trying to understand all this for months and still I just don’t get it I am trying to watch the fight tonight and I have cable and I also have the firestick with Kodi but I can’t seem to find how to watch this thing without having to pay the ungodly price. Can anyone offer me some step by step guidance please? Thank you and sorry Jennifer
@Jenn20601
Welcome to our community!
Follow this guide: Install guide.
Then look into the crew addon install which also has a guide.
Hey Jen & welcome…
Yur probly gonna need “The Crew” add-on for Kodi … or look into getting an iptv service ($10) for a mnth & watch that way & enjoy for the rest of mnth…
If you choose an iptv service, youll be hooked & probly wont go back to Kodi (more like cable)
The Crew is pretty self explanatory …Sports- pick your sport youll probly find some links
TP how to…
Hi, I would suggest the same & start by installing The Crew addon for Kodi & also look into getting a cheap IPTV service, there’s a section in here somewhere suggesting which services are good. Good luck.
Thank you all I am going to start over lol
Hi again, to be honest & make life much easier you could skip Kodi for now & just get a IPTV service & use Tivimate app.
@Jenn20601
Iptv vs kodi vs straming options will always be debatable.
Pick what suits you best and what you feel you need or is easy for you.
Iptv is a great option, fantastic.
Vod setups with kodi and real debrid are amazing and I prefer them, but it’s a preference and I hope you figure this out and see what you like. Try it all.
Plenty of guides and help here.
Absolutely install The Crew and Mad Titan. Deja Vu isn’t bad either for live sports and PPV’s. I’d say go with those but also try an IPTV. Install the add-ons as, depending on which IPTV you choose, it could be several hours, or minutes, before your email comes in with the set-up info. Also, if a service buffers you have back up options as well…
@Jenn20601
Give me a few minutes and I’ll find a free source for you using the Silk browser.
I guess I should ask. I’m not a fight fanatic.
What am I looking for?
I have UFC Dern v Rodriguez and
BKFC Joe “Diesel” Riggs v Melvin " The Young Assasin " Guillard
@Jenn20601
ronaldo7(.)io
Then click the UFC/MMA on the top banner and stream links will open. Now after prelims it goes to the main event feed.
Y’all are awesome Thank you all so much for all this information.
@Jenn20601
You are most welcome. Alot of people here with experience and knowledge.
Hope you get it worked out.
Hey all, just wondering if any one know of a list somewhere that maybe lists pros vs cons of these 3 (main?) types of streaming?
Or if there’s a summary of them out there someone I could find via search. Personally - never been a HUGE Kodi fan, find it a bit “too much” for me anyways. I’m reasonably good with tech, maybe I’m just missing something.
Anyways, thought others may have similar thoughts or have been wondering the same things so thought I’d post
Tia!
Here’s my Biased take.
Been using KODI since about 2017 it’s my go to for VOD shows and movies that my IPTV service doesn’t have
IPTV - Lot’s of crap out there. 90% is $hit. I lucked out and found an invite only service that is buffer free, underground, and dirt cheap ($6/month). I use this for Live News, Sports, and VOD
APK’s? I assume you mean like Cinema? Most of these are crap as well and I generally avoid them.
Like I said this is my biased opinion
Number 1 streaming app has to be stremio, once setup you dont need to do anything except enjoy ya streams.
Closely followed by kodi, lots of customisation settings, been using it since the xbmc days.
I dont bother with all the other apps like cinema, beetv etc.
As for iptv, i have a few subs but rarely use it as i just watch vod, dont really bother with sports.
Hey Hawk… take a few minutes and look at Troypoint.com. The lists you seek are there: best IPTV, best Free IPTV, best movie sites and much more.
If you really want to stream effectively, it’s all there. Troy spent thousands of hours gathering the information. Some information is restricted to Patrons but a lifetime Patron membership is CHEAP for what you receive!
I just back in to Kodi. I tried to follow the videos, but when downloading enigma the link was broken I believe it said. After I did the zip download. Download from repository, there’s nothing in program addons. So I didn’t get the build.
Help?
@GreenArcher75, It’s been awhile, but I’m suspecting that you had a misspelling, or punctuation error, when typing in the link address.
I would suggest that you take a look at this great tutorial video. It is really helpful when getting started.
