Have a new Fire Stick . Can’t find the tutorial for the settings in “My FireTV” settings. help please.
Thanks
Is this what you re looking for?
What would you like to know? The easiest way is to click through each heading and see what options are available, like turning on ADB Debugging and Install unknown apps in Developer options. Those are two you may want to enable. Other than that it’s all self explanatory. Legal, Sleep, restart, Reset. Highlighting each one brings up a brief explanation on the right.
As @Hgmartin provided a link for, there are many things that can be turned off to help speed up the firestick, although I wouldn’t exactly say hidden. Simply going to settings and clicking your way through each category will help you understand and use your Firestick more easily.
A post was split to a new topic: Firestick info and knowlege
You get a email when you sign up with tutorials.
