After reading Troy’s MeCool KM3 review I researched MeCool and found they had a 4/64GB unit with the S905X4 chip - the KM6 - just the specs I was looking for.
PROBLEM 1: Unit functioned as advertised for approx. 48 hours then shut itself off - no explanation in literature for shut down.
KM6 is not physically restricted and is not running hot - KM6 literature claims the unit should not overheat.
Only connection to KM6 is the power cord, HDMI cord and a mini-USB.
Remote unit will not communicate with KM6 unit to restart BUT will communicate for all other functions once powered up.
Restarting requires a reboot (removing power source.)
Issue repeats itself about every 48 hours - sometimes longer.
PROBLEM 2: The remote unit WILL turn the KM6 off - KM6 shuts off then immediately, without touching the remote again, turns itself back on.
Advised MeCool Customer Service(?) in writing - NO RESPONSE!
After 5 messages to WalMart’s supplier, it’s clear they are also being stonewalled by MeCool who want a video to see the problem. . a video of an intermittent event??
My MyGica and Mi Box units do not have this problem and are never turned off.
Is anyone else having a MeCool KM6 or is it
just a MeCool problem in general?
Am I doing something wrong?
Thankx in advance 4 your input. 2021-11-26T22:02:00Z
Sorry to hear that @rband13…I got a KM6 Deluxe this past summer, after watching every review I could find (including Troy’s) & haven’t had a problem whatsoever. Someone else posted about some serious problems with a KM3 model, I believe, but yours is the 1st for the KM6 that I’ve seen. Only advice I could give you, untill some professional help arrives, is to maybe try a factory reset & see if that does anything.
Good luck…
Thanks for your response . . Reset is my last resort because of my hi # of fav’s but increasingly looks like I might have to go that route . . Tkx again.
NP…I know what ya mean about the infamous reset…if you can deal with it a while longer, maybe someone here will have some better insight…or the company peeps will come up with something …ya never know.
I had the KM1 and the power supply went off on me,so i had to order one back to me and then that. was ok,but after that a couple of month the screen just went dark and I pulled the plug out and rebooted the box and I had the android robot there saying crashed…I tried to do a factory reset but on boot the Android robot was still there so i ordered the KM2 actually 2 lol and so far so good.it’s to bad there good boxe’s when there running and the reason why I like them is that there google certified and i like that fact that you can load certified apps from the store instead of Fork application.I hope that maybe that enough people out there that has similar problems maybe mecool will try to do something about it…because there going to go out of bizness …anyways thats this is just my 2 cent
just to chime in here. I also have 2 mecool km2 boxes. And although ive seen others with issues, mine have been pretty much tame. I set them up following Troypoints guide and no real problems other than a few remote issues. However you are not the first ive seen with problems with mecool boxes and they really need to step up. Their reputation is on trial. They need to chill with the amount of km 1-2-3-4-5 …etc and concentrate on getting one right before expanding so fast…just my 2 cents. …and although I have 2 km boxes only one is in use and one stays tuned up ready for service. My nvidea is best…hands down.
My km6 plus is constantly flashing a black screen at the beginning of a video. Anybody seeing this issue? This is occurring mostly on SmartTube but, will do it on the home screen as well. As usual Mecool wants a video of the problem. This is my last Mecool product until they either start fixing their issues or honoring their warranty.
Have same prob w YouTube . . cuts in and out for about 3-5 seconds when a new clip is loaded . . prob came with the unit . .have given up trying to fix it - just living with the prob because of the fast chip and plentiful RAM/
ROM and Flash. . Mecool no help.
unless its just a faulty box which is possible with any box I would dig deeper. My Km6 has been flawless and ive never seen the issues you are getting. Start simple and try a better hdmi cable, check bandwidth up and down and work out from there.
My KM1 Deluxe (4,32) has been great. However, two times in 6 months the screen has frozen and I got a humming from the speakers. It wasn’t like the usual buffering or stuttering and the remote was unresponsive. I believe it was the box. Cord restart and all was good. Hasn’t happened for a couple of months. The box seems to run properly warm, not hot, but now I set the box on it’s side for better cooling…maybe that’s the answer…but I doubt it.
Thank you for all the replies. Changing the HDMI cable was my first thought. I purschase a new certified cable. Problem still persist. Uninstall all apps except SmartTube and SS no change. I have the box hardwired ethernet cat5e cable using analiti download is running around 110Mbps with SS connected upload around 10Mbps. I just tried KGWAY suggestion waiting for the results. I have a mecool km3 box that doesn’t appear to have the issue. I will let you guys know it KGWAY suggestion helps.
another tip I do on all boxes to free up resources is force close any app that you do not use or un-install if not needed unless you are not sure what it is then be carefull but you can force close it and if it screws something up go back and re-start it. Generally mecool and ugoos type boxes dont have a lot of junk running in the background but there are some stock apps that do.
Success! ! ! Thankx 4 the heads up on that issue.
Another issue I have is when I scroll down to the bottom of my favourites list - about 4 or 5 lines arranged by date and time - when I get to the bottom line, the screen periodically freezes and the only way out is to reboot - a definite PITA. Is this unique to my unit . . have I programmed something wrong? Tkx.
