If I purchase the Fire TV Stick 4K Max along with an OTG adapter; UGREEN USB 3.0 Hub Ethernet Adapter Splitter Gigabit Network Converter and SanDisk Ultra 256 GB USB Flash Drive USB 3.0 as Troy uses in his instructions for expanding memory is there any need to consider a Flash Drive with higher GB or is 256GB the maximum that can be used?
Kinda not understandin why u would buy somethin with no storage, only to buy gagdets to make it maximum storage…
Maybe get somethin that has a decent amount of storage, the processor to drive it, already has ports to add more storage if u need it,
& get away from Amazonian updates
(for close to same $) $60-70 range
I can locate lots of info on adding extra storage for Firestick BUT is there a tutorial around to format USB for use with android device. I f this is in wrong place I apologize .
At the top of the page is a magnifying glass, this is the sites “search” function, click on it and enter “Format USB for Firestick” or something similiar and you’ll find many different and helpful posts.
Have fun and STREAM ON.
