Mad Titan Kodi + Jetextractors
Mad Titan Sports has stopped working.
I have tried uninstalling and reinstalling but when I try to reinstall it states that the dependency jetextractors has failed to install.
I have tried to follow alternate solutions from this forum, even to the extreme of clearing the data from Kodi and even uninstalling/reinstalling kodi.
Is Mad Titan down?
I don’t use it very often, but just tried to open Mad Titan and it doesn’t seem to be loading at all. Not sure what is going on. Maybe use DaddyLive for now until we figure it out?
Thank you for your reply.
Unbelievably, I have the same issue, (won’t load), but I have one item from Titan saved in my favourites and this loads OK.
Hopefully, a solution can be found.
Mad Titan has been rubbish for the last two months, i use Loop23 for Soccer and MLB, or Sport HD.
Thanks Kryten
Do you run this with Real Debrid or something
I don’t have real debrid, just a VPN set to Switzerland or France mainly for Premier League, Sport HD and Asgard are Loop good for sports.
MT wasn’t working earlier today for me but has since updated and now working great. So do an addon update.
Thanks Kryten. I might give these a try.
Thanks Riceyepie.
I have tried loading MT on one of the devices I had it installed on and you are right, it is working again.
However, when I have tried to install it on another device, it still wont install, stating that the dependency jetextractors has failed to install.
Does TP have an alternate installation update, like it did for Fen recently.
Not working! Gggrrr…I had MadTitan Sports for several months through the end of 2023. Kodi 20.2 on Xbox One S. It was working SO well. Went to enter Kodi and check out some live sports one day and instead of all the menu and link options within MadTitan it just listed Files, Videos, Playlist, and Search(or add videos) nothing was there. It come up with a log error message for JenPro, JetProxy and Universal Scrapers (using old schema - please update to definitions) I cannot find any info on this. I tried to update everything. I tried to uninstall and reinstall. Same thing. I did notice ghe version went from showing I believe 1.1.9 to 1.1.b?? Any ideas? Anyone have a working solution and/or reason for this? Would love to have it back up and running.
Hi Davelee7677
Sorry to hear that you are experiencing problems with MT. I know that it can be very frustrating.
My own MT has been working fine for several months but I was without it for a few days.
I don’t think I did anything specific to rectify my own issue other than persisting with updates and reinstalls every other day. Eventually, it became active again.
I can only assume that the developer kept tweaking updates and eventually it worked things out for me.
Hopefully yours will be sorted soon.
If you know how to install by zip,
this is the newest version of the addon which was updated on January 7th.
https://aftv.news/609694
Or just put in Downloader code 609694
And here is the newest version of Jet Extractors from January 7th also.
https://aftv.news/805343
Or Downloader code 805343
Jetextractors updated Automatically done today
I downloaded Mad Titan and jetextractor . How do I unzip them in Kodi ?
Use Downloader app to download them to your device, don’t delete or install, just click done. Go to Kodi and choose install from zip file. Navigate to the downloader folder on your device. Click on each of the 2 files you just downloaded and install.
Sweet! Thank you!
That is great news! I’ll be checking this out today!
I downloaded Mad Titan and Jetextractors using Downloader then opened Kodi install from zip file but I couldn’t find them or Downloader their .
I tried it too…
I located “downloader” by hitting the Browse button on the add source screen and then going to local storage. However, Kodi wouldn’t unzip the file, displaying a dependency error.
I did successfully install MT from the Magnetic repo and the link that I’m playing is currently streaming flawlessly.
https://magnetic.website/repo
After you click install from zip file you have to scroll down to where it says External storage. Then next you click Download. Then click Downloader. You should find the files in there.
