Looks the same as RedBox …just changed the name.
Ya but no options in this app. Can’t even remove unwanted countries.
Uninstalled the apk…
Ya I don’t blame ya.
Hi Shayde. I’ve got 2.8gb left of free storage. The rapid streamz app seems to be working fine for now. Still have an issue with live streams on KODI but I’ll persevere for now. Thanks again for all your assistance
I checked it out and it looks like redbox re-branded…actually other than the name it looks exactly like redbox ![]()
This is the same prob. I have. Just started a few days ago. Haven’t found a fix.
If using Nord this is a known issue. Switch to the TCP protocol.
One more thing. I tried to uninstall this app using ES File Explorer and it wouldn’t let me, giving me a warning that this app contained System files and I needed root access, which you can’t get on the Sticks. I did manage to remove it the usual way through manage installed apps.
you said your using a VPN. Set to any place in the USA.
Livenet TV gives multiple links. Better than others mentioned here IMHO.
