Links showing up but not playing
Continuing the discussion from The TV App not opening:
My links are showing up, but not playing, none of them, TV nor Movies. Please help…KODI/CREW/FEN/2 DIFFETENT FIRESTICK LOCATIONS. I cleared the cashe but did not help.
Welcome to this great community @7777jesus7777 :slightly_smiling_face:
If you’re using RD, you might want to make sure its not expired. Good luck :crossed_fingers:
Of you’re not using RD and looking for free shows, then use Scrubsv2.
I am using RD and it is not expired. Both Firesticks stopped at the same time.
The TV App addon for Kodi is not working right now. Needs an update.
better of using stand alone apps less problems
Is it possible my cable provider is blocking the content? If yes, how do I fix?
How do I use The Crew or FEN outside of Kodi?
you dont there are other apps that work well outside of kodi
On their home page on my browser I am now getting a pop up ad . Is it just me ?
It’s because you don’t have an adblocker on your browser. If I turn mine off I see them. If I turn it back on I don’t.
I have one Surf Shark that I have on all the time . This pop up only starter yesterday .
Surfshark doesn’t block everything unfortunately. I use Firefox as my browser and uBlock Origin as my adblocker extension and I don’t see those pop ups on that website. But if I turn uBlock Origin off, I do see those pop ups on that website. That should tell you everything you need to know.
100% if you’re not using a VPN.
I do not know how a VPN works. Surfshark seems to be the recommended one to use. If I purchase the VPN, do I need to install it on all my devices, or how does it get installed?
Here’s a couple tutorials from Troy on VPN’s.
I did use a VPN and it worked. I did have to reauth RD, but it worked as long as I used a US provider. Does RD need to be reauth every time I change the VPN?
It shouldn’t.
Post must be at least 20 characters
It never has for me. Whenever I move and need to establish my new IP address with RD I simply turn off the VPN, go to RD and login. Then turn my VPN back on and it makes no difference where my VPN server is located in the world. I keep a shortcut to RD home and one for device authorization on my home page.
Wow @Miki, sure got a lot in common. We even joined Troypoint on the same day. So, together, today, we shall both eat cake :birthday:.
Happy Cake Day :confetti_ball::partying_face:
