If you have fire tv player installed, does Vlc over write when using with the crew. Or do have to default it which if so I can’t find. Also anybody having issues with the crew buffering last two nites using real debrid. Thanx
When using kodi, use there native player. No need for vlc. To use vlc you have to manually select it within crew.
Have done it all. Never had a problem til after the resolver issued was fixed. Uninstalled crew, re installed now I have the problem. Re authorized debrid. Etc etc.
Well, based on the current post above RD may have had some issues.
I’ve tried everything TP, even the crew wizard for tweaking cache. I’ve re done everything again this morning , I’ve put Vlc on there but not defaulted, so it’s using evidently the crew player. I’ll see what happens tonite
The crew player is kodi, kodis player. I don’t think your buffering is relayed to kodi or your player.
You didnt try everything.
Lots of variables. Do a speed test vpn on and off
Done it all, the one thing I notice is when it stops. , pause it , wait 5 seconds, or fast forward couple seconds and it fine. It has done this before a long time ago the isl was going in and out. As soon as it does this I check with speed test on phone to make sure it’s up. Download speed is 87 mbps vpn on, as discussed using analyti only 1upload
if you are on a router try changing dns servers if possible. Might help
Yea thanx , I did that after reinstall this morning.
