def not over i watch all i need without a problem maybe try different apps
Maybe you should make a video on how you install Kodi and get it to work. Put it on YouTube!!!
not my thing just give what info i have and hope it helps the only thing i do is keep it simple i dont use builds and only use kodi as a back up with a few sports apps on it the rest for movies and tv prog i use stand alone apps all on firestick
Been using KODI for 6+years. It is all I use for Shows/Movies. Pretty hard to find consistent working streams without RD now.
Real Debrid subscription expired or the link is corrupted. Your account is still linked and therefore you can still see the streams, but they won’t play. Very simple explanation.
I had to add RD to stremio. Without it the feeds became very unstable if not at all.
Pretty odd. I just got done watching Stremio free feeds for my stuff without issues.
Thanks.
That’s interesting. Which apps would you recommend?
Pete
i sent message with list if you need any more info let me know
