Kodi not working like it always has
OK, y’all gonna think I’m crazy but here’s the deal. I went into the LR, turned on the tv, kodi, The Crew with/VPN as always and everything is back to normal. Don’t ask my how or why cause I don’t know the answer. I didn’t do anything for it to go haywire 18 days ago and didn’t do anything for it to come back to working right. When I check it, I always check it with the same show, episode, and watch to see how many streams are available. Streams are what they always are and it picked up and started playing on the first stream. I clicked on AutoPlay and it autoplayed like it always did before I started this post! I’m not gonna close this out in case there are more problems but there was an obvious glitch somewhere. Pardon my ignorance but is there the possibility a glitch can affect Kodi/VPN/TheCrew in only parts of the country and not others…I don’t know the answer. I’m in SE Louisiana and using a Dallas VPN server as the closest with the best lowest ping. Any other brains out there with any other ideas cause I’m just about tapped out? Thanks for all the attempts to solve this glitch. This may be unsolved and we may never know why but it’d be nice is someone who actually knew technically what could’ve happened so maybe we can help to fix it next time even if we don’t really know what we’re doing as it seemed that a lot of us didn’t know how to fix it! What say y’all?
Voodoo!
Glad its back!
I dont know the technical side but maybe whatever was causing the problem was fixed by yesterdays “solar flare” excuse.
Sometimes you just get lucky.
I finally learned how to operate KODI, but I still have a problem navigating it. That’s why I never have used a build. My favorite is Cinema HD. The only problem I have with it is sometimes it doesn’t play the sound . So I click on the HW button at the top right and click on it and you can click on HW plus and then you get sound with closed captions. If you can get sound without doing that please tell me how.
It was a problem with Real Debrid but it’s all good now
How are you for sure it was RD? Did you get a message somehow? Inside scoop? Just wondering? I’m happy it’s working but my RD turns out it was working on Serem and Asgard fine but not The Crew and it’s always been my go to for everything needing a VPN being used. I didn’t use a VPN before about 2018 until my MLB team I paid full price for said I couldn’t pick up home BB games because I was local. So I got a VPN and instead of me being local I could now be watching from Nebraska. Local to them was Tx,Ok,NM, Ark, and me in Lousiiana(350 miles away local) but I’ve been VPNing from then on.
VooDoo Is Real !!!
try another player like MX or VLC
Ok I installed the VLC PLAYER and I got sound. Thank you!!!
Pull plug on stick n internet. Then clear all cache n force stop all programs then use ex maintenance! I enable when I open them once it cleans disable ez maintenance. That has worked for me
I have tried to install the Kodi Xenon, but it will not work. I read that there is going to be a new version. Does anyone know when that will be?
https://troypoint.com/diggz-xenon-kodi-build-currently-unavailable/
Download the Kodi 21 RC2 on downloader and you can get all the diggz builds. You will have the Omega wizard installed instead of Nexus but its the same url.
I have been using the xenon plus build for a week and no problems so far.
This is what Pirate77 link to Troys article tells you to do also.
Ok I downloaded that version, but I need help from that point on. Does Troypoint have a video on what to do after you have downloaded this version. I am not very educated on how to do the rest without instructions.
if you just updated kodi apps should still be there if you did a clean install you will have to reload apps
Ok, so you downloaded the newest version of kodi or Diggz’ Omega Wizard on Kodi 21 RC2?
I have both on there. Sometimes it works, but most the time I have to do the one with closed captions to get sound.
I have it on my bedroom tv, but I had uninstalled it on the tv in the front room. It wasn’t working right. So I tried to reinstall it and it won’t download now. I believe a new version is coming soon. I just wait until it does.
If you have kodi 21RC2 from Downloader you can then download the Omega Wizard and install Diggz Xenon 2. Someome else on TP did it last night without any issues.
Http://diggz1.me/diggzrepo
I’ve noticed issues.
Was using 20.2 fork as my main application, with 18.9 full and 19.8 Fork as backups.
I don’t use RD and have always relied on free links. The past couple of weeks I notice they have gone.
On Scrubs2 I went from 30+ links to 9. None work. It’s the same 9 on every programme I try to watch.
I tried Nightwing - same 1 dead link for every episode. Diggz- same half dozen dead links.
I even installed the Troypoint 20.5 fork and installed the above - same result.
Tried various VPN locations including USA, Australia, Japan and several European countries.
Perhaps the days of free are just over?
Pete
