Make sure you have the latest update for the downloader.
There’s no Kodi 2.5
KODI 21.2 is the latest and it’s the first choice in Troy’s Toolbox
I waited a little while, i watched a couple of shows and now everything is working fine, i downloaded the Kodi 21.2 and now im downloading diggz. So all i had to was wait.
Way to go. No idea why the wait but sometimes you just accept that it works and move on.
Yeah i was rushing and i just what ever was on my mind. Apologize
No need to apologize, we’re all here just trying to help one another and I was confused
I’m in a similar situation. I was binging a season of a series, each episode was playing just fine. I got to episode 10 and suddenly each link gave an almost immediate pop-up error message:
“Playback failed. One or more items failed to play. Check the log for more information about this message.”
When I got this message previously I would employ several tips: restart the FireCube, go into FireCube settings, manage applications, clear cache, force stop and then relaunch Kodi. Sometimes I would clear cache and providers once I was back in a Kodi addon. I even got a recent tip to go into Kodi Settings, Player, Video and make sure the Adjust display refresh rate was set to OFF. One of these machinations usually worked to get an episode to play again. Alas, not this time.
I updated to 21.2 Omega hoping it would resolve my problem. It didn’t. I am using Nord VPN and primarily the addons Scrub V2 and Free99 (I don’t have Real Debrid). I saw someone mention making sure I have the latest version of ResolveUrl. I also saw the tip to disable or uninstall Elementum. I did that as well, all to no avail.
I’m flummoxed. Please help, all ideas welcome.
Did the log give you any clues as to where to focus your research for a fix?
I’ve never used the Addons that don’t require Real Debrid. But there’s the possibility those addons are no longer maintained by the Developer as you seem to have done all the proper troubleshooting. I suggest getting a subscription to Real Debrid (or comparable debrid service) and using it with Umbrella which is working great
I used The Crew and Seren with great success paired with Real Debrid. Have tried Umbrella with Premiumize and am very dissapointed. Now that Real Debrid is not available are their any workable options any more?
Who said RD isn’t available? It is still running and working just fine. I have Umbrella with PM as well. Both are flawless.
I use Umbrella and RD every day and it works flawlessly. Wherever your information that RD is not available came from, stop listening.
My RD works perfectly. It was only down for a few days and everyone panicked ![]()
I don’t believe it’s so much as our panicking than it was RD simply not working. I kept it for 2 months to allow my account to expire and I didn’t get any links that entire time in Kodi, Weyd, Stremio or Syncler with various addons.
I’m happy that you have made it work for you. I couldn’t and from what I’ve read here on Troy, I wasn’t alone.
After the RD api endpoint change the devs had to update all VOD add-ons and apps. Some of the Kodi devs were the first to implement that on some add-ons
Then Stremio and Syncler devs also implemented fix’s lastly following by the Weyd dev.
To get these fixes you had to update any of the add-ons or apps for them to work with RD correctly.
Without updating RD would have just failed.
Are you using the Real Debrid Manager program? Sometimes when that has an update it messes up all my loaded apps and I have to uninstall the manager all the time then reload in each app. I do not use the manager anymore, I just load Debrid in each one.
Did you check the date and time on your devices? If the date and time is incorrect things wont load or connect. Or if you use the programs (Manager) and load your Debrid and Trakt account into that - everytime Manager has a update it can cause your Debrid to not connect. I uninstalled Manager and have no more problems.
