KODI add-on problems
Haven’t been able to get FOD working lately. Looked at the error log but couldn’t make heads nor tails of it. lol. Anyone know what’s going on? Thanks.
TAD
Are you using IPVanish? If you are using IPVanish they are blocking some of the REPOs & addons. Basically anything that Is in the Narcacist or EzzerMac repos are blocked. If you disable IPVanish they work perfectly!
That was it! You hit the nail on the head. Do you think all VPN’s are being blocked? Thanks.
TAD
Do you know why IPVanish is blocking these REPOs?
I don’t know why it’s happened, it started last week when I tried to use Asgard but it’s quite concerning, it would be interesting to know what they found in these repos they didn’t like!
Reminder, if you turn off your VPN to get your addons and repos working you are also exposing your personal IP address.
Yes, I’m aware of that. Strange thing. I disconnected IPVanish, then loaded FOD, got a working link, and then went back and connected IPVanish and when I loaded KODI, the link was still there and working!
Tad, my friend doesn’t have a vpn provider yet. I was trying to get kodi installed and a build. Is there any other way to download kodi than using downloader? I did turn on download from unknow sources.
Of course. you can download from the official KODI website
Thank you Mark. I have gotten the problem resolved. I was able to get Kodi downloaded yesterday.
I g eat error. Then check log.i uninstalled and reinstalled.no did
@frncsmoore, I suggest that you look at this tutorial.
Anybody having problems with mylostsoulspace repo ? I can’t get any addons to install including Fights on Demand . I tried reinstalling the repo but now the repo wont install . Anybody having this problem with the repo ?
I gave up on FOD months ago. Can’t get any replays at all. Didn’t try to reinstall it though.
I just want to know if the Mylostsouls repo is down .
There is a repo called Lost Souls (without the My) in the build I use. Not sure how to get but you may have the wrong name.
FoD doesnt work there either.
had the same problem today, yesterday it was all good.
@scooterboy952
I’m not sure if this helps. But from a google search this came up and was posted about a month ago. Is it part of the Asgard Addon?
Asgard Location and Info
Repo Name: Narcacist Lost Souls Repository
Repo URL: https://mylostsoulspace.co.uk/repo/
Kodi Version Compatibility: 20 Nexus and 21 Omega
I had that repo installed in kodi but none of the addons will install or work . Thie addons worked from that repo worked last week but not now . Is it working for anybody else ?
If no one responds here you might want to pose the question on that thread at the Wirelesshack
