KODI 20 with THE CREW = loads no good links
Rd account is good until May 2025
Yes press continue. Also in RD go to My Devices and it will list all of your authorizations based on what you named them after your successful attempt.
Is there anything in the list?
Yes, there are 6 Kodi’s with opensource app all dated (authorized) today.
Ok. So you did authorize.
And did you verify in the Crew that it shows your RD account info under Universal Resolvers2?
I believe so. Selected re-authorize my account.
I was using my iPhone. Tried with my desktop and the same result.
Ok a few last tries for me and then I’m stumped…
Open Crew and goto Tools.
Click ResolverURL setting
Make sure Enable Universal Resolvers is highlighted
If not highlight it and click OK at bottom
Go down to Providers and go to the left to Real-debrid Providers. Make sure they are alll highlighted.
I will show my screen shots but keep in mind I use a build and dont need to do all of this stuff. I authorize once for all my addons. This is how my build set up is for Crew not sure if yours looks the same.
I’m stumped two. I have tried all the steps as I have done many times in the past with success. Now it seems not to work. Cannot figure out what I am missing.
You could try going to your device list on Real-debrid and deleting everything before your next attempt.
Good idea @PapaS. I was thinking that too. All his authorized attempts might be causing an error.
I doubt that is it. I never clear my devices and literally have dozens in there. Never has been an issue
But are you authorizing it to the same addon in the same kodi in one day like we believe @hammer has done?
About 6 months ago I had an issue where I would authorize rd in Kodi, Weyd and Syncler but as soon as I would try to watch something, I’d get the no stream available so I’d check the authorize setting and sure enough it wasn’t showing that I was authorized anymore. This was happening on 2 different devices and I was losing my mind. Finally someone on some group which I can’t remember said they experienced the same thing before and told me to try that. I deleted the entire list which I never cleared in a couple of years but it seemed to fix it because I haven’t had that problem since, so I just thought I’d throw it out there. :person_shrugging:
I will try deleting the device list. I have a smaller onn in the office that works with real debrid. Try switching them and work on the one that cannot connect to rd. Close to my desktop. Thanks for all the support. But don’t give up.
Well @hammer, @MarkxG is right. Its not the issue. Since i have some time before hockey starts i decided to test the over authorized theory.
I downloaded troy fork 21.1. Installed The Crew and only The crew as per Troys instructions. I then authorized RD without issue and received many links to movies. I then reauthorized RD without resetting the aithorization and was able to get links without issue.
I am done for now. Not sure where the issue is but it seems it is on your end.
Success. Did a couple of things. First I deleted the device list. Then completely uninstalled CREW. Reinstalled CREW and went through the steps to authorize real-debris, and bingo. Don’t know the true reason it worked this time, but thankful. Thanks again to all.
