Had the same issue. Re-authorized Read Debrid and all works fine now.
MarkX,
I installed RD. It caps out at 100 links. It would pull in torrent links that were magenta colored. Non RD links are in neon green.
I clicked several RD links. None worked.
This is why I say RD was trash from the beginning. It pulls linksâfree and not freeâbut the links did not work. Maybe I needed to go through all 100 links, but seriously? Not something Iâm willing to entertain for every single query.
I took someoneâs advice yesterdayâ advice from this blogâand onstream has worked like a charm.
Prior to trying RD, I was easily able to get good links, albeit 720 p, with Kodi. I receive Troyâs newslettersâand decided, âletâs try this.â
I donât know what Iâm doing wrong. If maybe the VPN is interfering.
I decided to try the blog to see if there are resources.
I havenât been using FS longâmaybe a year.
Iâm glad youâre doing well with RD & Kodi.
Rkujay
What do you mean youâve re-authorized RD?
I would highly suggest watching the video Jayhawks659 posted above.
He does a great job of explaining RD and how to set it up using The Crew in Kodi.
Based on what you have said here, I am guessing that you only have torrents enabled through the resolver. While these links will potentially work, if you want something with far less hassle than you need to enable âcached torrentsâ only. Make sure this is also selected in the settings menu.
Again the video posted by Jayhawks does a tremendous job of explaining the process. I think he goes into detail of this specific task at around the 38:45 mark.
Okay after reading your reply Iâm pretty sure you have not authorized RD. Sure you may have an active RD subscription but if itâs not authorized in your build/addon itâs not going to work. There is nothing linking your RD to KODI.
As others have said Iâd recommend watching Jayhawkâs detailed video especially around the 41 minute mark where he talks about Real Debrid
MarkX
Do you have a subscription to real - debrid?
PapaS
I use a VPN that Troy from TroyPoint endorses, if thatâs the ?.
RD was downloading PAID and FREE links.
I definitely am not subscribing. Subscription based has got hot water written all over it. No credit card information from me. I donât know who owns these apps, etc.
AMD237
Are you subscribing to Real Debrid (RD)?
Oh absolutely, and Orion as well.
SexyItaly11
Try onstream.
MarkX
Yes. I enabled torrents on RD ⌠using the CREW.
Open KODI
Select Add Ons
Select The Crew
Select Tools
Youâll see RD. Then you can enable torrents.
I do not pay for a RD Subscription.
Do you?
AMD237
Maybe thatâs where Iâm running into a problem.
I wonât give any CC info to apps. I donât know who writes them.
This is copied from Troyâs latest email:
Real-Debrid is Now a Must Have
Itâs gotten to the point where you can no longer depend on free links that the various streaming APKs offer.
Due to legal pressures, there are less and less free streaming apps being released. The ones that are available come with crappy low quality links that buffer like crazy.
Real-Debrid integrates with all of the popular free streaming apps, Kodi addons, and builds.
AMD,
I must not be explaining myself well.
I had downloaded real debrid.
It did not matter âmovie or tvâthere are up to 100 links.
The links did not work.
My RD links are in the color Magenta.
Pirate suggested ONSTREAM yesterday. That works.
It is VERY risky to supplement CC info. Iâm not saying donât do it. Itâs personal preference.
Iâm simply sayingâŚred flag.
Hopefully (Iâll try RD again) it will work without a subscription.
You have utterly and completely lost me lol. You are saying you âdownloadedâ Real Debrid and then talk about how you donât pay with a credit card and then hopefully Real Debrid will work without a subscription. It doesnt work without a paid sub, are you sure you are familiar with the same RD that we are talking about in here?
Pre-paid credit card?
Okay gotta get on you a bit here. You post how bad Real Debrid is more than once. Several of us have tried to help you only to find out you donât even have a subscription to RD? LOL Iâll never get that time wasted back ![]()
Iâm starting to think he downloaded this on his device https://m.apkpure.com/real-debrid/com.realdebrid.realdebrid, and assumes that will magically give him the premium links.
This is posted so many times in here, please read through this before we go any farther:
Yup as long as he purchases a RD Sub that video is all he needs
AMD237
Youâre right partially.
It provides the links in magenta WITH NO SUBSCRIPTION. The links do not work. What is confusing is this:
RD gives torrented links in two categories:
- PAID
- FREE
You select something, right?
Next screen is a madly running list something like this:
RD PAID 4K 1080 720
RD FREE 4K 1080 720
The third line is like this (below with no RD)
4K 1080 720
So help me understand something. Why pay RD if they have free links?
Obviously they are sourcing themâŚ
Iâm not intending to confuse anyone. Iâm saying I did not enroll in a paid for Real Debrid. Yet both paid & free links are supplied.
Why pay when it seems there are free links? That is confusing to me. It seems like youâre baffled too.
So basically RD with no subscription gives free links that simply theyâve disabled. Thatâs so classy.
