I hope that Troy sees this and can share some of his remote settings. I have an LG TV with a TIVO OTA (for local channels) box, and just received a KM2 PLUS DELUXE box. I had to upgrade from a KM6 that used the LeeTV Netflix hack, and apparently Netflix found a way to disable it. I am trying to configure the KM2 so that I can turn off the TV and KM2, and then power up both from the KM2 remote. I used to be able to turn on both from the KM6, then if I wanted to watch local channels, simply press “guide” on the TIVO remote. I have tried the remote patch file on the Troypoint Toolbox to no avail. Any chance that you could share your remote/CMC settings?
