Kinhank G1 Android TV Box First Impressions/Setup Video
Lots of talk on the Insider about the Kinhank G1 Android TV Box.
Here’s my First Impressions Video with Setup Guide.
Kinhank G1 Android TV Box Amazon
Kinhank Official Website
FYI for the Canadian gang the Kinhank G1 is $134.29
Skimmed through the video. Decent looking box but even at $99 I don’t see enough value that a similarly spec’d out T95Z Plus at roughly 1/2 the price or less doesn’t do Especially if you don’t care about Certification
For certification just use the $20 ONN when needed.
Troy,
Thank you for the great first impression video. Amazon has 8% off now. But, limited stock. Think I’ll try it out as well. Like the ease of setup.
I just ordered, will let you all know how easy it is for me to setup. Wish it was 64gb for $100 price tag. I did get $8 off. I can always return, if setup frustrates me. I like easy android box setups.
good lookin’ box…waiting on the final verdict :face_with_monocle:
It’ll be interesting to see if Kodi 20.4 works on this device. It doesn’t work on the Onn box; 20.3 runs okay.
best bet for kodi is a cheap stock android box. I like keeping kodi on a seperate box…imho.
So, how would it compare to the Onn 4K box for $20? Did get one of those and deciding what we want to do for the other TV. We’ve had 4K Firesticks and we are seeing the direction they are going. So no plans to keep that. Maybe still try to sell locally to someone else after a factory reset.
Tried the t95z plus. That box has android phone version not TV. Some some tools will not work with t95 like button mapper.
Agreed this is Stock Android. If you cared about Certification to say run HD Netflix, Prime and other things then you don’t get the T95Z. I don’t care about certification and don’t use Button Mapper, Netflix or Prime as I get all of that content on KODI.
What build do you prefer to use in Kodi, use RD and a VPN?
I’ve been using the Grindhouse Builds for about 5 years. The Dev is on top of things. RD+Trakt. I do not use a VPN
I just installed Grind house with RD. Nice builds. Fairly quick loading as well. Thanks
Anybody having low volume issueswith the Kinhank G1. Would appreciate input if available. Thanks
@Disco,
Sorry, I returned mine. I decided to wait on a cheaper price with 64gb.
Yes, definitely, and the volume varies greatly from channel to channel and app to app.
Ty for reply. Just returned mine.
I have troubles with the volume too. Stremio have to crank the volume almost all the way up, put it on my IPTV through TV mate and i have to turn all the way down. And that’s on the shield Pro.
