Jellyfin Setup Tutorial for 2025 - Perfect for Firestick & Android TV
Originally published at: Jellyfin Setup Tutorial for 2025 - Perfect for Firestick & Android TV
In this article, we are going to show you how to easily install and setup Jellyfin on a PC, and then access it on a streaming device. This is perfect for Amazon Fire TV and Android TV systems. This is a quick-start guide and we will dive deeper into additional details and use-cases in the…
Thanks Troy and YES - PLEASE continue with follow up tutorials for JellyFin! I have the perfect mini PC im going to configure and tuck away specifically for a JF Server. Ive been looking to make the plunge into this - Debating which platform to use, and now im convinced that JF is the way to go for my needs.
Thanks for the input @Reece Planning on doing a ton of content around this if people want it. Got a good video coming soon regarding this for Patrons.
A fairly big advantage of JF over Plex is that JF will work on your LAN if the ISP is down.
I will add that I’m using a Linux computer (Zorin distro) as our JF server and it does work very well.
IMO, the UI of the JF server is a little clunkier, less intuitive than the Plex server. Also, Plex clients can scrap external subtitles and I haven’t found a way of doing that with JF clients. But external SRT files can be accessed and installed on the server and then they’re available on the JF clients.
Before I go down this rabbit hole… Does this work with a MacBook and Onn.4K Pro?
Is it safe to assume that the hosting PC must remain powered on at all times for this to work?
I have been struggling to have a home media server. I have a TP-Link router, with USB storage option, and files are always constantly corrupted or inaccessible, despite having a USB-C connection and using a Samsung EVO 970 nVme drive. I really wish this option had worked, as the router is always on.
In my home, between 2 kids and 4 nosey cats, I’d have to put the PC in the attic or garage for the safety/integrity of the unit, and that’s just not feasible. I really wished that were a suitable option, because the attached drive is not noticeable.
Hello, yes, if you watch my video and read the article you will see that it supports macos. I also use Onn 4K Pro in the video as well.
I leave mine on at all times but you could turn it on only when you want to use it.
I’ll double TP’s vouching regarding the ONN Pro.
I cannot comment regarding any experience with using a Mac as a server.
Can Jellyfin be used with HD Homerun to get local channel tv?
I’m assuming that your Samsung drive is in an external case.
Two questions: Is that case powdered?
And, have you considered shopping for a small computer to use as your server?
I’m using a used Dell minicomputer that I bought for $70 from Discount Computer Depot’s eBay store. You should be able to find an inexpensive unit from somewhere that can be hidden from cats and kids.
Goggle “Jellyfin live TV”.
IIRC, Jellyfin only works with Homerun devices as tuners.
I utilized a USB-C OTG cable, and GaN charger to provide power to it, then connected it to the router so it would not be in the mercy of a low-powered port on the router.
Do you have an example of the type of mini pc you mention? That seems very inexpensive.
post deleted by me
I use Emby and Plex which are also free. Is there any difference? Clarification… does the PC need to be on and can you use it remotely?
post deleted by me
Mine is a Dell 7050 mini. It’s about 7”x7”x1.5".
Amazon has been running specials on machines much smaller than that under $150.
I use Jellyfin remotely. I use Tailscale, a type of private VPN, to facilitate that.
If I’m not mistaken, Plex is putting the ability to remotely access your content behind their Plex Plus paywall.
I have been trying to install jellyfin server on my Zima board, but it’s not finding my files held on the added hd , any help ?
I’m assuming that your SBC is using some form of Linux as an OS.
If that’s the case, you have to manually add the drive’s name, computer name and the folder, essentially the path in which JF will access the content .
IIRC, it is similar to : /media drive/computer/movies
I’ll double check that when I get a chance later today.
